ElectroLumen
- Joined
- Jan 18, 2017
- Messages
- 3
Hello,
Brand new here and I hope this is the best place for this post. I am working on a fixture using Luxeon Z leds (http://www.luxeonstar.com/assets/downloads/DS120.pdf) of which a 3 tier fixture ( it is going to be modular) uses 21 LED's. At this point I am exploring the wiring restrictions and options. When testing the LED's running them at their suggested current of 700ma and 500ma I found that they were way over the brightness I am looking for. I think that even running these at 350mA would be sufficient for lumen output per LED. I will be using a constant current driver for these but am really looking to see what would be a safe and efficient way to run this many of these LEDS. That said there is limited room for wiring and I would also need to work within UL Low voltage standards (ideally).
When looking at wiring in parallel even under driving these the total current needed would be 7.35A, which seems like it may not be a great idea, the wires would also need to account for current.
I want to avoid using resistors since the space is limited and the wasted energy involved. That said I have very limited experience with LED driving in this type of design and could be misplacing my approach. I have attached an image of a combination circuit that seems to make sense and the specs of the LEDs for reference. Please take a look and let me know if you have any thoughts or ideas on creating such a fixture. FYI the lumen output does not need to be 100% and I actually think these should be run at 1/3-1/2 the maximum brightness since its mostly decorative.
> Combination circuit and led specs > https://i.imgsafe.org/fbb3f3e9f2.jpg
If I have not provided any info needed please let me know, I appreciate any help I can get on this project.
Thanks.
Thanks.
