going big
joachimk
Belgium
Packhorse
New Zealand
I am almost finished building my scooter 12S li ion pack. Its 50.4 volt 20.8 amp hour.
Should run a LED like that for a couple of hours.
joachimk
Belgium
i'm building now a lifepo4 pack to see if it will work for the led.
for now everything is working so have to see how it is in the caves
hydropower
You do plan to use some sort of regulator I hope? Would be a shame to burn the LED because of too high current!
joachimk
Belgium
yes i did, it is fixed at around 6A
just need a way to put the steps in 25% 50 % 100%
than i will be ok
jspeybro
Belgium
if you're using a driver like the H6CC driver from taskled, you could use FETs to switch between different resistors connected to the potentiometer contacts.
I once made such a setup giving me 2 modes on a H6CC and magnetic switching via read contacts. I never finished the light though due to a problem with the host I planned to use.
I guess the schematic can be modified to use 3 modes.
