Hello folks,
I'm looking to build an adjustable focusing system for my Nichia 219 LED. From what I have read so far, there are three main types of lenses to consider for this application: Plano Convex (PCX), Double sided convex (DCX) and Aspheric.
One of the concepts I have read about is that you want a small focal length relative to the diameter so that the lens can capture a wider spread of light from the LED. But I think I will already have to make a small reflector around the LED to redirect light that sprays out at more than, say 40 degrees.
The aspheric lens is supposed to be the best about abberations, but is that really important?
The DCX lens seems best about having a small focal length, but I have read that the light-gathering abilities at the edges are not as good because the light hits the curved surface at a more glancing angle
PCX lens at least has a flat surface that faces the LED, but they are harder to find with small focal lengths.
My guess at how the focusing system would work is that at maximum throw, the LED is at the focal point of the lens, and for more spread, the LED moves closer to the lens.
