Mateminco TK01vn - 21700 Tank
Skylumen
  • 144mm Lenngth, 38mm head, 29mm Body, 32.5mm Tail
  • 6.8oz with 21700
  • TK must stands for TANK because it is!
  • Incredible glossy fit and finish
  • Email for Black & Gold color
  • Rear forward/momentary switch turn light ON/OFF only
  • Side switch single click cycle ML-Low-Medium-High
  • Double Click = Turbo, Press and hold = Strobe
  • XHP50.2 6500K 2800L, 31Kcd, 352m
50.2 6500K $108
50.2 ~4500K SD $118
70.2 4000K
$145
70.2 6500K $145
Skylumen
This light is definitely larger for what it is. Pros and Cons obviously. But it is an excellent one.
SKV89
Vinh, can you share how you opened the bezel? I tried twisting it off with all kinds of different rubber grip but it won't come off. Seems glued super tight. What tools did you use to open it?
Skylumen
I press the front of the bezel onto gorilla tape while wearing blue garden gloves and it comes right out. Gotta put lots of muscle in though.
texas cop
Texas
You can use the shaft of a square shank screwdriver as a T-bar in the bezel notches. Rubber jar gripper for the head.
Newlumen
United States
Ok. I got the original bezel removed.
i heat the bezel on the stove for like 10-15 seconds.
use the knife to twist it..
SKV89
interesting methods. I have that butcher knife. I will give it a try!
