degarb
http://intl-outdoor.com/ld4b-24a-17mm-buck-driver-3v16v-p-817.html
I am looking for a video how to find and modify the resistor to change the default current. . Many others will want to lower it, to raise current. . For me, I want to lower it. . Still doubt the 2 other settings will be, nor are, useful. . I am guessing the driver designer use pwm to lower the current in mid and low mode. If I could remove their pwm, and add my own infinitely variable pwm, all the better. Main thing here is clear graphic or video to change out that resistor. . I am guessing the value range is so low and narrow that no pot would spec in range.
