Capolini
Banned
This is a Protected CYTAC 18650 3400mAh BT battery that I discovered is a NCR18650B RE WRAP. 2.8 years old.
I noticed that when I put this battery in the charger that it continues to slip off of the positive contact terminal. It seemed that the BT was out of alignment so I decided to re wrap it and center the little White retaining ring better. I could actually move the BT back and forth with my thumb nail. That can not be good,it should be stabilized and have no movement! This is when I decided to sacrifice the battery!When I unwrapped it there was the typical Panasonic NCR18650B underneath.
I proceeded to take off the NCR wrap to completely expose the battery. I took off the protection circuit on the bottom,so now the wire that leads to the positive contact was the only thing holding it.
I AM AN AMATEUR and a NOVICE WHEN IT COMES TO ELECTRONICS!:naughty:
At this point I decided to REMOVE/BREAK OFF the wire so that the protection circuit was not dangling and so I could get a better view as to why the BT was not stationary as it should be. So I got out my mini craftsmen screw driver! As soon as I tried to severe the wire connected at the BT end there was a small spark and a puff of smoke! No doubt I short circuited the battery,that was my first thought! Second thought was,,,,,,,,is this battery going to vent or possibly explode now?! I got a bit concerned and put the battery outside on my balcony. I was ready to go to bed and thought,"what if" this battery vents or explodes?! So I wrapped it up[afraid to recycle at this point!] and threw it in the DOGGY trash can that that is provided for the residents.So if there is a it will be far enough away from my Second story condo!!!
A FEW QUESTIONS:
1.With the BT being unstable what would have been the worst thing to happen if I continued to use and charge this battery? a SHORT or worse?
2.Was there any DANGER in me trying to break off the protection wire which resulted in a puff of smoke and a small spark?!
3.How is the BT fastened? I did not get a chance to find out because I STOPPED MY EXPERIMENT when the spark and puff of smoke happened! I think I heard someone on here say w/ some glue and that white retaining ring!
TIME IS YOURS LADIES AND GENTLEMEN,,,,,,WHAT ARE YOUR THOUGHTS?
A FEW QUESTIONS:
