Quick question about McR20 Seoul reflector...
KDOG3
Sea Isle City, NJ
I have a WO bin Seoul P4 emitter on the way along with a McR20 Seoul edition reflector. My question is since the reflector is made for the Seoul, will I have to raise the emitter at all? Or can I just plop it in the space where the original emitter was? I'm puttin this in a KL1 head. Thanks.
ROK
Dynamic Land
Already done mine.
You don't need to raise the emitter. Just swap the emitter and insert the McR20-S.
Perfect! no more mod needed.
Another good point is GAP,between upper and lower part with McR20, disappeared.
KDOG3
Sea Isle City, NJ
Do I need to worry about the reflector contacting those electrical points on the top of the emitter?
ROK
Dynamic Land
Don't worry. Reflector has been seated on the plastic shoulder.
KDOG3
Sea Isle City, NJ
Ok great. The anticipation is killing. Got my fingers crossed the mailman drops off both items today....
ROK
Dynamic Land
This is the KL1-R.
If you swap the stock optic with McR20. You can see the small gap between upper and lower parts. McR20-S is shorter than McR20. So, that makes perfect match.
To disassemble the KL1 is terrible. But it's not to me. :nana:
kenster said:
Me too?:thinking: Must be some new P4 emitters and Mcr20S reflectors other than the ones I have used I guess???:candle:
DaFABRICATA
Michigan
How much shorter?
I just ordered the Mcr20 specifically for this mod.
Is it any different than the mcr20 OTHER THAT the length?
If so, I can just shave her down a bit.
bombelman
Seoul Reflectors are 0.75mm or 0.030" shorten then regular McR.
I've used stock McR-20 in KL1 head and it worked perfect :)
Nereus
Espoo, Finland, Northern Europe
DaFABRICATA said:
How much shorter?
You can find the dimensions of both Mcr20 and Mcr20s reflectors in the Sandwich Shoppe website.
-N
