CLHC
This folding saw from Silky came today.
Unsheathed
Weight and Measures
Safety Halfway Hard Stop Lock Before Closing
Saw Blade
GOM Rubber Grip
The Straight of Silky
Strapped on Back
In Hand
Specifications
Length :Overall 46-3/8" (1,185mm), Blade 19-4/5" (500mm), Closed 26" (665mm)
Weight : With Sheath 2 lb (920 g), Operating 2 lb (920 g)
Material : Aluminum Alloy, GOM Rubber, Steel
Metal : SK4 High Carbon Steel
Blade Thickness, mm : 2
Kerf, mm : 1.75
Initial Counter Top Impressions
This Silky Katanaboy feels quite solid in hand. It's just something one has to feel for themselves, if there's a Silky dealer in the area with said folding saw. This "folding" saw does not feel cheap whatsoever, of course that's my take on it. Everything on this saw is metal with the exception being the GOM Rubber that's encasing the metal handle and the black plastic covering the metal safety metal screw. With the Screw Up = Unlocked, the Screw Down = Locked. There are replacement blades available. Did I mention that the saw blades' teeth are sharp!
That's all for now.
Unsheathed
Weight and Measures
Saw Blade
GOM Rubber Grip
Strapped on Back
In Hand
Specifications
Kerf, mm : 1.75
That's all for now.
