Triple triple/ triple quad/ quad quad driver
Weld Inspector
Michigan
Is there a driver capable of powering 3- triples, 3- quads, or 4 quads? Playing with an idea ha ent been able to find info on wiring multiple mcpcbs on one driver dont want to go direct drive was thinking 2 maybe 3 cells in series to get the voltage up
mcbrat
Iowa
The old Mac 3300L used 3 lux-rc L333 boards. One as a master, 2 slaves. 2 cell setup. Not sure if you can do the same with the current 371d boards.... But that would be pretty pricey.
mcbrat
Iowa
Really though, most any driver should work depending on how you are wiring. Any of the pop can sized multi emitter light type drivers. Just need to make sure the batteries can handle the load...
staticx57
NJ
Just wire the quads and triples in parallel and you can use any of the normal 3V drivers. Board these days let you run the LEDs in parallelas well so in essence every LED will be in parallel
