Top list - The most discussed flashlights of the past 12 months
kreisl
"?"-column: q = questionable. kreis105 suggestion has not been 100% fully adopted in the present firmware version 1.05, hmm. therefore suggesting again as kreis106 suggestion for FW1.06.
p#?parameter settingsMC3000 firmware FW1.07iMax B6mini firmware 1.10iCharger 106B+ firmware 3.14kreis107 suggestion for FW1.08DC2 comments
01NiMH MODES
  1. {Charge|
  2. Refresh|
  3. Break_in|
  4. Discharge|
  5. Cycle}
  1. {Charge|
  2. Discharge|
  3. Cycle}
  1. {Charge|
  2. Discharge|
  3. Cycle|
  4. Forming_charge}
unchanged
02NiMH CHARGE rate{0.05|0.06|…|2.99|3.00}A{0.1|0.2|…|5.9|6.0}A{0.05|0.06|…|0.1|0.2|…|9.9|10.0}Aunchanged
03NiMH CHARGE capacity cut-off{OFF|100|200|…|49900|50000}mAh
safety factor=1.0 for DCHG
safety factor=1.0 for CHG
{OFF|100|200|…|49900|50000}mAh safety factor=1.0{OFF|100|200|…|99800|99900}mAh safety factor=1.0unchanged
04NiMH CHARGE alt. algorithmsN/A{CHARGE Man|CHARGE Auto}
unchangedWhatzz Man
05NiMH CHARGE delta peak{0dV|1|2|3|4|…|19|20}mV
{4|5|…|14|15}mV
NiMH RE-PEAK {1|2|3}
NiCd RE-PEAK {1|2|3}
PEAK DELAY {OFF|1|2|…|5}min
NiMH {1|2|3|4|…|19|20}mV
NiCd {1|2|…|8|…|19|20}mV
unchangedvoltage plateau "0△V"
06NiMH CHARGE trickle charge{OFF|10|20|…|290|300}mA{OFF|50|51|…|299|300}mA{OFF|10|20|…|490|500}mAunchangedsame for NiCd, OFF for NiZn
07NiMH CHARGE target voltage{1.47|1.48|…|1.79|1.80}VN/AN/Aunchanged
08NiMH CHARGE restart voltage{OFF|1.30|1.31|…|1.44|1.45}VN/AN/Aunchanged
09NiMH DISCHARGE rate{-0.05|-0.06|…|-1.99|-2.00}A{0.1|0.2|…|1.9|2.0}A{0.05|0.06|…|0.1|0.2|…|6.9|7.0}Aunchanged
10NiMH DISCHARGE delta peak{OFF}N/AN/Aunchanged
11NiMH DISCHARGE delta peak{OFF}N/AN/Aunchanged
12NiMH DISCHARGE cut-off volts{0.10|0.11|…|1.09|1.10}V{0.1|0.2|…|1.0|1.1}V/Cell{0.1|0.2|…|28.9|29.0}Vunchanged
13NiMH DISCHARGE reduce{-Zero|-0.01|-0.02|-0.03|…|-1.98|-1.99|OFF}AN/A{OFF|5|6|…|99|100}%unchanged
14NiMH CYCLE number{1|2|…|98|99}{1|2|…|4|5}{1|2|…|998|999}unchangedmemory
15NiMH CYCLE modes{C>D|C>D>C|D>C|D>C>D}{D>C|C>D}{D>C|C>D}unchanged
16NiMH BREAK_IN currentCHG = 0.1C fixed to 2 decimals
DCHG = -0.2C fixed to 2 decimals
N/AN/A
( FORMING CHARGE ≠ BREAK_IN )
unchanged
17NiMH BREAK_IN cut-off volts{0.10|0.11|…|1.09|1.10}VN/AN/Aunchanged
44NiMH BREAK_IN mode{C>D>C|D>C>D}N/AN/Aunchanged
18NiMH BREAK_IN rest time{0|1|2|…|239|240}min for CHG
{0|1|2|…|239|240}min for DCHG
N/AN/Aunchangeddefault: 60min
19Temperature cut-off
{OFF|20|21|…|69|70}°C {OFF|68|69|…|157|158}°F
{OFF|20|21|…|79|80}°C
{OFF|68|69|71|…|174|176}°F
{OFF|68|69|…|175|176}°F
unchanged battery
20Time cut-off{OFF|1|2|…|1439|1440}min{OFF|1|2|…|719|720}min{OFF|1|2|…|998|999}minunchangedtotal time
21Rest Time{0|1|2|…|239|240}min for CHG
{1|2|…|60}min{0|1|2|…|60}minunchanged
22qOutput limitN/AMax Power Set: {50|51|…|59|60}WDischarge: {5|10|15|20}W
Charge: {Auto|50|60|…|250}W
:thinking:fancy
23Input limitmin volts: {10.0|10.1|…|11.9|12.0}Vmin volts: {10.0|10.1|…|10.9|11.0}Vmin volts: {10.0|10.1|…|14.9|15.0}V
max amps: {1|2|…|21|22}A
unchangedKISS
24Back-light{Auto|1|3|5|ALWAYS ON|OFF}min {Always On}{0|5|10|…|95|100}%unchanged
25Cooling Fan{Auto|OFF|ON|20|25|…|45|50}°C
{Auto|OFF|ON|68|77|…|113|122}°F
{Auto}{OFF|Auto|ON}unchanged
26Beep Sound
pitch {OFF|1|2|…|15|16}
Key stroke {ON|OFF}
Buzzer {ON|OFF}
Key stroke {ON|OFF}
Buzzer {ON|OFF}
Completion {5×|3min|Always|OFF}
unchangedtwo octaves
27Settings-saved User Programs{01|02|…|29|30}{1|2|…|9|10}{00|01|…|08|09}unchanged
28LITHIUM MODES
  1. {Charge|
  2. Refresh|
  3. Storage|
  4. Discharge|
  5. Cycle}
  1. {Charge|
  2. Storage|
  3. Discharge}
  1. {Charge|
  2. Storage|
  3. Discharge|
  4. Cycle|
  5. Monitor}
unchanged
29LITHIUM CHARGE rate{0.05|0.06|…|2.99|3.00}A{0.1|0.2|…|5.9|6.0}A{0.05|0.06|…|0.1|0.2|…|9.9|10.0}Aunchanged
30LITHIUM DISCHARGE rate{-0.05|-0.06|…|-1.99|-2.00}A
{0.1|0.2|…|1.9|2.0}A{0.05|0.06|…|0.1|0.2|…|6.9|7.0}Aunchangedrestrictions apply
31LiIon CHARGE target voltage{4.00|4.01|…|4.24|4.25}V
Lilo {4.08|4.09|…|4.19|4.20}V
LiPo {4.18|4.19|…|4.24|4.25}V
Lilo {3.90|3.91|…|4.19|4.20}V
LiPo {4.00|4.01|…|4.29|4.30}V
unchanged4.20V
41aLiIon CHARGE restart voltage{OFF|3.98|3.99|…|4.17|4.18}V
N/A
N/Aunchanged
32LiIon STORAGE voltage{3.65|3.66|…|3.99|4.00}V Lilo {3.70V}
LiPo {3.80V}
Lilo {3.75V}
LiPo {3.85V}
unchanged3.80V
33LiIon DISCHARGE cut-off{2.50|2.51|…|3.64|3.65}VLilo {2.9|3.0|3.1|3.2}V
LiPo {3.0|3.1|3.2|3.3}V
Lilo {2.50|2.51|…|4.09|4.10}V
LiPo {3.00|3.01|…|4.19|4.20}V
unchanged
3.00V
34LiIo4.35 CHARGE target voltage{4.10|4.11|…|4.39|4.40}VN/A
N/A
unchanged4.35V
41bLiIo4.35 CHARGE restart voltage{OFF|4.08|4.09|…|4.32|4.33}V
N/AN/Aunchanged
35LiIo4.35 STORAGE voltage{3.75|3.76|…|4.09|4.10}V
N/A
N/Aunchanged3.90V
36LiIo4.35 DISCHARGE cut-off{2.65|2.66|…|3.74|3.75}VN/AN/A
unchanged3.30V
37LiFe CHARGE target voltage{3.40|3.41|…|3.64|3.65}V
{3.58|3.59|…|3.69|3.70}V{3.40|3.41|…|3.89|3.90}V
unchanged3.60V
41cLiFe CHARGE restart voltage{OFF|3.38|3.39|…|3.57|3.58}V
N/AN/A
unchanged
38LiFe STORAGE voltage{3.15|3.16|…|3.39|3.40}V
{3.30V}{3.30V}unchanged3.30V
39LiFe DISCHARGE cut-off{2.00|2.01|…|3.14|3.15}V{2.6|2.7|2.8|2.9}V{2.00|2.01|…|3.59|3.60}V
unchanged2.90V
40LITHIUM CHARGE termination{Zero|0.01|0.02|…|2.98|2.99|OFF}A{0.1C|0.2C}{0.1C|0.2C}unchanged
45LITHIUM DISCHARGE reduce{-Zero|-0.01|-0.02|…|-1.98|-1.99|OFF}AN/A{OFF|5|6|…|99|100}%unchangedrestrictions apply
42LITHIUM CYCLE modes{C>D|C>D>C|D>C|D>C>D}N/A{D>C|C>D}unchanged
43LITHIUM CYCLE number{1|2|…|98|99}N/A{1|2|…|998|999}unchangedmemory
more detailed notes:
y(x) = b + m*xSLOT#1SLOT#2SLOT#3SLOT#4
NiMH vertices-2.28526 + 1.01459*x6.18635 + 0.993133*x-7.37368 + 1.02647*x-3.85048 + 0.986388*x
NiMH regression-1.94549 + 1.01478*x7.27019 + 0.992784*x-6.68242 + 1.02620*x-2.50386 + 0.986388*x
LiIon vertices-1.49737 + 1.01390*x6.77945 + 0.991513*x-6.73327 + 1.02492*x-3.01876 + 0.982359*x
LiIon regression-1.14895 + 1.01324*x7.77560 + 0.991026*x-7.37074 + 1.02477*x-1.55080 + 0.982172*x
kreisl
i have 2pcs of TF18350, i'll do the same test np. identical program number in slot4 and slot1. will also do continuous logging with latest dex jar
here are my test results, learning as i am typing. once i've finished writing this post, i'll and you'll learn if i got the same prob as the op, so let's see:
#1 : [01]
spv: "CYCLE 1: 674mAh / CYCLE 2: 674mAh / Capacity: 675mAh"
"CYCLE 1: -2.46Wh / CYCLE 2: -2.46Wh / Energy: -2.466Wh" (lil bug, all three numbers should be displayed with 3 decimals)
tov: "mah: 675"
dex: (D) > C > D > C > D = (D) > 667mAh > -674mAh > 668mAh > -674mAh (and 8mins later in the log: -675mAh wth)
dex: (D) > C > D > C > D = (D) > 2.618Wh > -2.468Wh > 2.625Wh > -2.466Wh
perfect energy result. dex calculated energy is the same as mc3k (and as excel). am not sure why the capacity counter went up by 1mAh after the program had finished. will investigate. actually, at the time of writing tov now shows 677mAh
#4 : [01]
spv: "CYCLE 1: 438mAh / CYCLE 2: 427mAh / Capacity: 427mAh"
"CYCLE 1: -1.53Wh / CYCLE 2: -1.49Wh / Energy: -1.491Wh" (lil bug, all three numbers should be displayed with 3 decimals)
tov: "mah: 427"
(D) > C > D > C > D = (D) > 476mAh > -438mAh > 451mAh > -427mAh (and 60mins+ later in the log: -427mAh, unchanged)
(D) > C > D > C > D = (D) > 1.918Wh > -1.538Wh > 1.825Wh > -1.492Wh
i'll call this also a perfect energy result. The 0.001Wh difference comes from differing numerics in coding (integer, float, double, round). the lcd shows as expected 427mAh, the result of the final Discharge routine, and even hours later the lcd still shows correctly 427mAh.
biglights
thanks biglights!
i plan to update this interesting top list once in a while when i observe major or plenty changes in either list. The Nitecore E-series has certain potential to enter the Front Page or the Reviews Top 20, imho.
I agree I have the EC1 and it is pretty awesome! Was thinking about getting the EA2 or maybe wait for EC2.
This list must of took a lot of time.
kreisl
i got my USB cables today and here are some measurements by me:
green braided FT cable, 94cm 20g 3.4mm 6.60mm 5.55A notes
white original J5 cable, 71cm 16g 5.6mm 3.00mm
white original(?) Note3 cable, 95cm 5.9mm, 25g 4.0mm
black original Tomtom cable, 144cm, ~35.5g 3.5mm 5.85mm
blue authentic Remax cable, 45g, 94cm 3.7mm x 13.3mm 6.03mm
transferlengthqualitythicknessmicrotomo
white original J5 USB cabledata71cm16g0.2253.00mm5.6mm1.40A/1.30Afeels light, thin
white original(?) Note3 USB cabledata95cm25g0.263
4.0mm5.9mm1.26A
green braided FT USB cabledata94cm20g0.2133.4mm6.60mm0.78A/0.64A
black original Tomtom USB cabledata144cm35.5g0.2473.5mm5.85mm0.88A/0.73A
blue authentic Remax USB cabledata94cm45g0.4793.7mm×13.3mm6.03mm1.75A/0.60A
white original Pebble USB cablecharge19.5cm12g0.6154.00mm6.1mm1.75A/1.75A
black original Powerchimp USB cablecharge56cm11.5g0.2051.54mm×5.20mm6.00mm1.50A/1.50A
black Manker U11 USB cablecharge35cm10g0.2863.3mm6.0mm1.50A
black Xtar MC1 USB cablecharge77cm15g0.1953.0mm6.0mm0.90A
black Liitokala Lii-100 USB cablecharge58cm18g0.3103.5mm6.40mm1.74A
safasfd
asfasdf
LAB
Son of beech, sheet! How long did it take you to aquire all this info?
tickled
Some of the ones on the list like the Q50 don't actually exist.
tatasal
Any kind of reply is counted? Regardless of topic? ( negative or positive / praises or complaints )
