Some questions about the Shark driver
Icarus
Belgium
Shark Converter board images.
Remora Microprocessor board for the Shark.
http://i221.photobucket.com/albums/dd291/dat2zip/t640_IMG_9829.jpg
Table of Contents:
General Information: LINK (Post #2)
Using external resistors instead of onboard trim pot: Here, Here, Here
Hooking up an external pot: Here (Post #34)
Shark Efficiency graph with 3 Crees: Here ( Post #159 )
Shark Efficiency graph with 6 Crees: Here (Post #159 )
Shark Driving 3 LEDs information: Here (Post #202 )
Remora + Shark + Shark +...: Here
Removing the trim pot: Here
Vout tracks Vin. What's wrong?: Here ( Shark Advisory thread )
dat2zip
Bay Area
The Shark has both a voltage feedback and current feedback internally. The regulator can be thought of as a voltage regulator with current limiting.
Sharks sold before Nov 2006
J1 is jumpered and configured for Vout of ~22V
Sharks sold after Oct 2007
J1 has no function. New batch of boards from the CM configuring Vout to be ~26V. All boards sold beginning in 2008 have the copper C soldered onto the backside.
2. What about regulation? The specs says Voltage OR Current???
Yes, it's both. Just like a power supply you can set the voltage and current limit seperately.
If voltage and current regulator is still confusing you. Simply jumper J1 for LED driver applications and the Shark will be a constant current regulator with open circuit protection of ~22V and the trim pot sets the LED current.
3. Is the driver, with and without the jumper, open circuit protected?
Any voltage regulator is "safe" since it will regulate to a given voltage. For the Shark it will regulate to 11.5V or 22V with no load depending on whether J1 is jumpered or not.
4. Last sentence says "The Trim pot input can also be PWM controlled via a microprocessor".
The trim pot feeds the control pin. If you remove the trim pot you can hook up a microprocesor to control this pin.
The Microprocessor board for the Shark is called the Remora board. The resistor comes with the Remora board (not installed as shown). It makes the two pin header connection to mount the Remora board as the holes on the Remora board are very tiny and most standard wires will not fit. After installation you cut off the upper part leaving two posts.
A general rule of thumb to use the Shark.
1) Determine the number of LEDs you want to drive in series. Example: 4 Lux3s.
2) Determine the series voltage of the LEDs at the desired current. Example: 1A which means ~4V/LED and 4LEDs = 4 * 4V = 16V (approximately)
3) Determine the operating and min battery voltages using the total Vf output. Operating is > 1/2 output and min is approximately 1/3 Vout.
Operating should be greater than 1/2 of 16 Volts or a fresh battery pack should be 8+ volts.
At end of battery life your battery voltage should not drop below ~ 1/3 Vout or 1/3 of 16 = 5.3V
In this example a 9V stack of AAs batteries or a 12V stack of AA batteries would be fine for this example. What won't work is 2AAs, 4AAs since the current demand will approach the limit of the regulator.
Example 2:
Three low Vf LuxV. say you have 3 LuxVs with Vf of approximately 7V @ 700mA. That's 21V which is below the 22V open circuit protection (with J1 jumpered).
1/2 21V is 10.5V and 1/3 21 is 7V.
A 12V battery pack would suffice for this application. A 9V battery pack would be marginal for this application.
Wayne
Icarus
Belgium
What about efficiency of the Shark driver?
Any chance you'll offer a decent external potmeter to go with the Shark?
Is it allowed/necessary to pot the Shark?
Can't wait for the microprocessor board to be released.
You should give this the highest priority. :whistle:
Tri-LuxV + microprocessor controlled Shark would be... :duck: :devil:
Icarus
Belgium
:popcorn:
IsaacHayes
Missouri
it can run a hotwire mod if the bulb is rated for 11.5v or 22 volts. That is the limit of the voltage output. Depending on the bulb and what current it draws will also be a limiting factor as the board is only adjustable for 980ma max...
dat2zip
Bay Area
The board by default is as described.
There are 0402 SMT resistors that set the voltage which could be changed for voltage regulation to some other voltage like 12.5V, 9V or something else. Even though the resistors are tiny it's not impossible to change with a little care, patience and magnifying devices. A good fine tip soldering iron helps as well.
The primary current sense resistor is a 0.1 ohm resistor which sets the upper end of the current to 1A. Cutting this value to 1/2 would increase the upper current limit to 2A for example. I would solder a 0.05 0603 in place of the current 0.1 ohm sense resistor. Same resistors that are used on Badboy, Nexgen, Wizard and Downboy. Putting a 2nd one on top of the first (two 0.05 ohm resistors) would kick up the output to 4A. Probably not acheivable with a switch limit of 4A, but, the trim pot would allow you to dial out as much as the converter can dish. I would seriously heat sink this if you are driving multiple LEDs with this much current. Three K2 LEDs at 1.5A could be in the 18W range which means the converter losses would be in the 1-2W range for a 80%-90% efficiency. Four K2s would be 24W on the output or more.
The only caveot is to ensure you have a boost configuration under all conditions. Letting Vin rise higher than Vout will put the converter in DD mode and will most likely Fry the converter board, LED and possibly the battery. That's not a good situation.
Since this converter was designed for no holds bar efficiency and power the converter, inductor and diode were all choosen to meet or exceed the requirements of the converter board.
Since the internal switch current limit is ~4A, that would set the input side current limit to 4A. While I simplified it above and may have infered less than that as limits, it was only to make it simple for those who know little about electronics and should for the most part keep the novices from getting into trouble. For the more advanced users this converter board has the most beef no worries about inductor saturating, or diode overheating.
This sucker was built like a tank.
Running large input or output current as usual will always result in losses in the converter board and converter components. Always take this into consideration and a good rule of thumb would be 85% efficiency for computing the power that will be absorbed by the converter board components. if the power losses in the converter are larger than 1W I would consider heat sinking the converter board or at least provide some thermal relief for the heat to migrate away from the converter board.
Wayne
cy
USA
thanks for the info, was wondering about the new shark driver
Icarus
Belgium
Did I already mention there are a couple Sharkies on the way to me... :devil: :whistle:
goldserve
Toronto, Canada
I have some questions about the PWM to the enable pin?
How does one get the microcontroller powered by the shark board. Is there a fixed voltage out of around 5V? How would you go about designing a pic to be used with this board. Thanks!
dat2zip
Bay Area
Adding a microprocessor is left to the user as an exercise.
There is a pad on the converter board that you can pick off the battery voltage, the internal reference, control pin and GND.
With this signals an external board could be devised that housed a linear regulator, microprocessor and support circuitry to drive the control pin.
There are many application notes on Maxim, National, Linear, TI and other web sites on specific ICs and external PWM control
Wayne
Gryloc
Cincinnati, Ohio & North Lewisburg, Ohio
Sorry to pull up an old post, but could someone tell me if the Shark driver could be used with an external potentiometer? How would one go about doing this (and what value pot must I use)? I love my Fatman, and it is a awesome driver, but I wonder if the Shark would better suite my 4 Luxeon III D-Maglite ran from 6-8AA's. My maglite has a potentiometer built into the head for dimming, so I would hate to get a Shark and find it is difficult to use it with a pot. I worry my Fatman will fail me (and I worry all the time that I may break a wire by twisting the head to dim my flashlight and open the circuit up, destroying the Fatman). I hear how the Shark is built like a tank and it can handle up to 4A of power at a time (from either the input or output). I wonder if George would sell a beefed up Fatman to keep up with the cpmpetition. I heard that you can replace a few resistors and add a diode that can handle greater amounts of current. I hear of people with Fatmans that can take the heat because of this small mod. Anyways, its getting too late here in Ohio. Thanks.
-Tony
dat2zip
Bay Area
Yes!
Make sure to pot the Shark driver or heat sink as it will be dissipating 1W or so of power in the converter board.
I've already wired one up and put the OSTAR 6 chip on a large processor heat sink with fan. Works great. (J1 needs to be jumpered).
I have another Shark in a Mag host driving three LuxVs. I added a small momentary push button switch so that the default is low approximately 100mA or so. When the button is pressed you get momentary high (burst mode). I like this setup since I only need high on occasion and low is typically more than adequate. I take this one with me when I go geocaching at night. I used my flood PD when I get close to be more stealthy and I used a narrow single Mag Lux3 to look into bushes instead of using my hand/arm.
-Wayne
Stuart B said:
Hi
Can the shark be used to drive an OSRAM OSTAR 6 chip?
Cheers,
Stu
Stuart B
England
Excellent...just needf to get my paws on a couple these and a couple of 6 chips now :).
Stu
dat2zip said:
Yes!
-Wayne
hank
Berkeley CA
I'm staring at my M@g 4D and 5D -- is anyone building Shark-based mods for those yet?
IsaacHayes
Missouri
I think I did my math correctly, and this would work to drive 4xCree's in series that had a Vf of 3.6 at 700ma from 3xNiMH at 3.6volts. Input current would be 3.5amps which is ok. I'd really like to do 1amp to them in parallel via some sort of DB4000 but oh well.
Now a question, will I have to measure current with a DMM when setting the pot to get it at 700ma, or can I just crank it and it will try it's best? Or would that not work and it would drop out of regulation/not function right off the bat?
