Astrolux S41S help
Polynikes
Got an S41 for my birthday, and it seems to be stuck in demo mode or something? I'm new to lights so forgive me if this is a dumb problem... but if I turn it on say to turbo mode, it will run for a few then go down to the next lowest mode and continue to do so until it's not emitting any light at all (switch still "on" as in I have to press twice to get the light back on) I don't really understand the diagram it came with but it doesn't say anything about a demo mode or anything anyway...
how do I get it to run normally?
Thanks for your advice in advance...
Poly
Need a Light?
What type of battery are you using? Is it a quality name brand IMR cell? I could maybe see a ****fire 16340 maybe acting like this, if it's dying fast? Congrats on the light btw, just got mine in 219b flavor and quite like it!
Polynikes
I plan to run my 18650s when I get the other tube in so I just went to radio shack and snagged these for the time being...
mines 219b also lol
jorn
Norway
sounds like a dead battery issue. Mine act like that when barreries are emty :) Recharge, if it continue to act up like this, get a new battery.
Polynikes
Kind of what I was thinking, like maybe I got a bad battery or something. I forgot my charger at work though :mad: so it's gonna have to wait until tomorrow.
redvalkyrie
I had the same issue with mine. It's the battery. I was using a Efest IMR and when the issue started I put the battery on a DMM it rad 2.8v. These lights drain 18350s extremely quickly.
redvalkyrie
So, I guess the next logical question is can a 18650 tube be purchased for the S41 to make its runtime a bit more useful?
thslw8jg
The Gulf Coast
The s41 uses the same driver as the BLF A6 and begins stepping down output at 2.8 volts. If the battery drops below 2.8 volt under load the driver turns the light off preventing damage to the battery(over discharge)
mvyrmnd
Australia
Yes, it can - and they're not expensive either. They're on Banggood
I have the S2 which is the same driver with a XP-L emitter instead. in Turbo it pulls just over 5A from my IMR18350. This equates to a runtime of ~8 mins. It's a beast, but if you want runtime you need a 18650 :)
Polynikes
Thanks for the info guys, I already have an 18650 tube on the way... guess I'll just have to be patient. Lol
ChrisGarrett
Miami, Florida
Ven gave me a light with the LD-2 driver board that direct drives on high at about 6A. It's a Convoy S2+ Triple XP-L HI and I got the 18350 body for it, as it comes set up for 18650s.
I found two AWT IMR 18350s that are good up to about 7A realistically, but I get about 8+ minutes on high, so don't expect much. After about 2-3 minutes, the light shuts down thermally, so those 8 minutes are going to take about 30 minutes to blow through.
Look for something like the AWT, if you want to run it in '18350' configuration.
Chris
redvalkyrie
I found Astrolux S41 18650 bodies on Amazon Prime. $14.00 which is about $10 more than Banggood but you'll get the part in two days and no waiting for customs or China mail.
jorn
Norway
I almost never use the 18650 tube. Love the smallish 18350 size. Runtime? Not that bad for a edc as long as you dont always use the turbo mode :)
redvalkyrie
See, that's my problem. I'm blind as a bat and need that turbo mode. I actually used it to paint some automotive parts black last night and the Nichia emitters really made it easy to make sure I was getting an even coat across the part.
ven
Manchester UK
As said the 18350 can not take the demand(looks wrong chemistry to). IMR18350 will see you right, keeppower/AWT have been fine for me over time.
18650, look at samsung 30Q or sony vtc6................or ideally 10a+ ................15a+ better.
I like the 18650 body as (obviously gives far better run times) but also helps balance out a top heavy light. Still pretty compact as well, short body when you need a more compact carry.
redvalkyrie
I received my 18650 body and am running a Sony VTC6. So much better! I actually have decent runtime on turbo now whereas with the 18350 it seemed like I'd get five minutes before the light began stepping down into its lowest mode. Plus the rainbow colored body looks great with the stainless head and tailcap. This sucker does get hot though.
Polynikes
Just got my 18650 tube, but my VTC6s aren't here yet.
Waiting impatiently.
Polynikes
I put an 18650 tube on, got the Sony VTC6s charged them up, and my light is still stepping down exactly the same as it was before... any thoughts? I've had this thing for 2 weeks and haven't been able to use it.
RollerBoySE
Sweden
It's timer based, so it will always be 40 seconds.
