asdalton
I came up with a formula for measuring the overall efficiency of a flashlight--one that should be more useful than the more familiar numbers such as bulb lumens, lumens per watt, etc. The idea is to correlate the energy input in batteries (not watts) to the relevant output in beam lumens (not lamp or emitter lumens) over time.
The goal is to estimate how many lumen-hours per cell a flashlight can achieve. This metric accounts for the entire chain of possible inefficiencies--battery internal resistance, regulator losses, emitter losses, and optical losses. The metric also accounts for more cells providing more output or runtime. For now, I have limited myself to 123A lithium cells for the purpose of simple comparisons.
Most of the numbers are based on data from flashlightreviews.com. Lumens were taken as initial lumens, and the time is estimated according to how long the batteries would last if the initial brightness were maintained. I did this by eye from the output curves. More precisely, it would be in integrated lumen-hours over the battery life, divided by the initial lumens.
Here is my graph for some popular flashlights (Luxeon lights divided by one or two cells):
Here we can see that the Inova T1, Longbow Micra, and Nuwai Q3 have pretty poor efficiencies. The E1L and Amilite are a little better. A large segment of the flashlights on the graph lie along a horizontal line from the E2L to the L4. These lights have roughly the same efficiency despite a wide range of light output.
The Inova T2 and Surefire KL3 are particularly good among the 2x123A Luxeon flashlights. This efficiency likely comes from pulling a low current from a high voltage power source. The batteries and regulator are not being strained as they are in the more strongly driven flashlights.
The Dorcy 1x123A Luxeon is surprisingly good, and it will still be good even if you use a more conservative normalized runtime estimate of 2 hours rather than 2.5 like I used. Having a Q bin instead of R will knock the efficiency down even more.
There's not too much of a surprise that the HDS 60 gets a very high efficiency on its underdriven primary beam. The maximum beam looks better on the graph than it probably should, since it's running at full power for only about half of the normalized runtime.
The 2 cell incandescents aren't too bad, especially when compared to some of the more poorly-performing Luxeon lights such as the Nuwai Q3. However, the data for the E1e show why 1-cell incandescents aren't too popular.
