Imalent
Results 1 to 17 of 17
Thread: UV light for finding where the dog has maid a mess?
    Nov 2005
    Amman, Jordan
    Default UV light for finding where the dog has maid a mess?
    Pretty self-explanatory. Any suggestions? I notice that the sandwich shoppe has some UV alephs....
    Nov 2005
    Amman, Jordan
    Default Re: UV light for finding where the dog has maid a mess?
    You guys are killing me.... come on.
    Try just using a flourescent blacklight.
    $4 fer a blacklight bulb...
    Unless you were looking fer a LED flashlight solution...
    Jan 2005
    Graham, WA
    Unfortunately, this isn't as easy as it sounds because so many different things are flourescent--like any body fluids for example. Bring your black light with you the next time you stay in a Hotel and you'll see what I mean. Sometimes different fibers in your carpet are flourescent and other times things that are simply white appear to be flourescent.
    Flashaholic* PhantomZ's Avatar
    Sep 2004
    49N 123W Eh~
    you can try here, www.UVflashlights.com
    there's a chart that will show what wavelength (nm) is best for what type of stuff you are looking to light up. i ordered a few 380nm LEDs cause it looks like the best all around use (i'll be using it to see where my dog made a mess as well)
    ppl have used inova x5uv. others have found those cheap made in china, bought on ebay to work well for them.
    if you find a uv light that works for you, pls post your results
    Flashaholic* TORCH_BOY's Avatar
    Jan 2004
    Australia, Vic
    Who need a UV light, Just use your Nose
    Quote Originally Posted by PhantomZ
    We actually have a bag of 380nm LEDs that had some static damage... They are about 10% bad out of the bag, and 10% or so failure some time after install (for those that appear working). I was going to offer them as a 25 for $10 or something to CPF members for fillding with, since they are too labor intensive to go through
    But, 380nm is an excellent wavelength for detecting pet stains and provides good contrast, and even lets you tell the difference between vomit, urine, other, etc once you get an eye for it!
    Piers
    Ultraviolet, Infrared, and BloodTracker flashlights
    Quote Originally Posted by xenopus
    Piers
    If you have blood, vomit, urine, etc. on your carpet....you may have other problems than just needing a UV light.
    Sep 2004
    49N 123W Eh~
    Piers
    i hope those static damage ones were not the ones you sent to Peak LED Solutions??!?? they recieved the package already.
    i'm sure they're not :P (crossing fingers)
    thanks for your help Piers with me and Peak Solution
    The early bird gets the worm, but it's the second mouse that gets the cheese.
    Flashaholic RadarGreg's Avatar
    May 2002
    Bamberg
    Why would it not be possible to manufacture a flashlight using a SF U2-like design that allows you to switch between different UV LEDs? It would be handy to have one light that could have one position for 400nm, another for 365nm, etc. I'd think a switchable flashlight with four positions would just about cover all the UV range. Just a thought...
    RadarGreg
    RadarGreg
    "If you can read this, thank a teacher. If you can read this in English, thank a Soldier. If you can read this in the dark, thank a Flashaholic."
    Mar 2005
    Saint Louis
    Piers
    I wouldn't mind picking those up. Send a PM with your PP address, and PP will be sent.
    Ah, no -- definitely not! We ordered new ones, marked the bad ones clearly, and put them away. We were going to ditch them, but then it seemed such
    a waste when I am sure there are good homes for them
    Piers!
    Quote Originally Posted by RadarGreg
    RadarGreg
    Radar:
    We have ones that select between up to four wavelengths, with different modes of combinations
    Piers
    I recently picked one of these up for the same reason, also to find where I had a mouse getting in ...works great, not too expensive http://www.dlsenterprises.citymax.co...07/1709585.htm
    Steve
    Sep 2004
    Thanks, this thread made me laugh. I too thought it would be cool to have a black light to use to see where fluids from people or animals has been. I forgot totally about the inexpensive light they sell at walmart for a few bucks that uses a 4 inch tube. I may pick one up next time I am there. I think it uses 4 aa batteries. Of course nothing like having an LED one.
    Ok, back to the humor, most blind people I know put a baggie over their hand like you get your groceries packed in at walmart, feel around for it, grab it, turn the bag inside out, tie it off and put it in an outside trash can at the corner or there trashcan at the end of their driveway.
    http://www.tadgear.com/x-treme%20gea...nova_x5_uv.htm
    the X5Ts are good flood lights, good for finding stuff in a room, but has HORRIBLE throw
