depusm12
Just curious if you can frost a M*G charger bulb or a WA1160 using glass etching cream. Or will that cause the bulb to build up more heat and explode?
Luna said:Frosting should help dissapate the heat faster due to the greater surface area.
As for precautions, HF is scary but I think the concentrations found in the hobby version is a bit safer. You still should use gloves and eye protection and have a bit of baking soda close just in case.
