I've read most of the threads about the m6 and it's usually in a comparo pic with a modded maglite... now what I would like to do is make a similar light in a similar body with a lower cost...
I thought I would go the ROP route but I do not want to use rechargables... I think a distinct advantage the m6 has is it only needs 6 cr123a's... no charger or battery pack...
I'm not sure the exact runtime of the m6 but I would like something with similar output, slightly lower or higher [600 Real lumen], in a flashlight that can last at least one hour... I already have a 4D maglite so using that would be a plus but if another Mag size is better or another host is better let me hear it.
I would prefer to run it on plane old alkalines as they are readily available, the lithium AA's are really expensive so let's keep them out of this one...
What I have come to believe is if I modded the switch to lower the resistance, got an aluminum reflector, a boroflat lense, 4 x D--> 3AA adapters and a voltage regulation circuit I could probably run a ROP bulb or similar for an hour at least (12 x AA batteries), with similar output to a Surefire albeit slightly larger... would 12 AA's be too much for a regulation circuit to bring down to 7.2v?
Advice appreciated!
Advice appreciated!
