missionaryman
So I think the 10W Mag HID and mini HID is a great invention and I take my hat off to it's parent's but I'm starting to get over the whole buy a m*glite, chuck half of it away, bore it, cut it, gut it and stuff it and there's your highly compromised superlight.
I want to build a host for a tubular torch style HID light that will accomodate anything from 10w to 50w.
How hard can it be?
It's just some threaded aluminium tube, reflector, lens, head, batteries and a few other electrical bits right?
I want it to run on NiMH cells so it will be cheaper to build & charge.
Here's the major problem - I don't know anything about HID lights. I think that's a problem you can all help me with however.
Can someone give me the run down - let's focusing on a 50W system.
What type of bulb do I need, what voltage & current would it run at?
Could I just get an automotive type "plug & play" kit & house it all in somehow?
What capacity would the batteries have to be to supply 2hrs run time?
Do you need heavy guage metal reflectors and heat resistent glass lenses like with Incan hotwires or does put out HID less heat?
Would a Carley 2101/2103 reflector work ok?
How hard can it be?
