BatteryCharger
I have a flashlight which normally runs on 4 NiMh AAs. I was using a 3 cell stock mag bulb in it, but it finally burned out. What is the brightest 4.8v or less PR bulb I can use, and where do I buy it?
I have some 4 volt, 0.9A PR bulbs.BatteryCharger said:I have a flashlight which normally runs on 4 NiMh AAs. I was using a 3 cell stock mag bulb in it, but it finally burned out. What is the brightest 4.8v or less PR bulb I can use, and where do I buy it?
Bill, you are right. Brightest 4 cell bulb is WA1183 but when it powered by 4AAs with battery holder, then resistance of battery holder is an issue.bwaites said:Because its not REALLY a HOTWIRE unless its overdriven!!
Bill
