Pellidon
After looking at Silverfox's charts for batteries I was curious about what different brands of batteries did in certain lights. Being on Vacation and more or less bored I set up the followiing test. I decided to post it now as one of my test units died :scowl: so I won't test with a replacement unless I start over.
Light one is a Fenix L1P Now dead like a goldfish :toilet:
Light two is a Led Lenser David 19 aka Coast Digi-Tac II
Both are (were) luxeon lights with converters. The Fenix was the high output test sample where the David was the relatively low power longer runtime unit. The test was partially to see what initial differences the batteries had on each light.
Light meter readings made on a Meterman 631 at one foot. DMM was a Harbor Freight upper end model.
Battery voltages are not made on a battery tester, just a volt meter to show free cell voltages.
This is not intended to be an optic vs reflector test. It is a demonstration of how the cells behave in certain units. Once the Fenix gets better I might try it again and run the cells to exhaustion.
More comments to follow.
