Doug Owen said: Sorry to disagree, it is absolutely relevant. To the device being powered, everything is fine.
Again, if you call a 10% discharged alkaline dead (because it's now 8.4 Volts) you'd better not advertise you can use 9 Volt Alkaline batteries......
And yes, alkaline has larger capacity (although some of that is at a lower voltage and may not be useful.....). However this is a great step up for the already useful NiMH batteries in this size. If it doesn't suit you, don't buy it.
Doug Owen
I don't understand, unless you own every 9V device ever made, how you could say that there "won't" be a problem. I've never had a problem using 9V Ni-MH batteries but who knows for sure, you?
I know that we're talking 9V batteries here but there was one report of a camera not powering up using Battery Station's AA lithium cells. Another user had to start up with the screen OFF to avoid the initial voltage drop at start up. I on the other hand I got such great runtime in my Fluke 189 with these cells that Fluke asked BS for samples to test!
Another point is that I had ten IPower Ni-MH 9V batteries that were pure junk. I didn't get very many cycles if you want to call them cycles. I sent a couple to Silverfox for testing and he had the same problem. He disected one and found a dead cell.
Ipower is coming out with a new model Ni-MH 9V battery shortly.
