If I want to switch over to using Pilas instead of the four 123a's in my SF M-4, can you tell me how many, and which model of Pilas to get, and also which replacement bulb (and where to get them)?
Thanks!
Thanks!
Wow, great info. That might explain why my G&P G120 lamp was able to get three good cycles from my Wolf Eyes 150B and 168B cells, only to hot-flash the fourth time. Perhaps the first three times, I eagerly eyed the green LED and removed the cells at <4.1V. I use both Wolf Eyes "smart" chargers (CH02 and DH02) and AW's DSD.Lunarmodule said:On Pila brand chargers, the LED turns green indicating "done" when the cell is at only 4.08-4.09V, but when left on the charger for a significant time after green LED is on it "trickles" upward very sowly to final out around 4.19V. DSD chargers (common 4-bay 2-way LiIon chargers from Lighthound AW eBay and others) do the same thing. ...
0.12V may not seem like much but to some incan bulbs can be life or death.
LuxLuthor said:I got my 168s Pilas today from Burlys, and although once charged they work great in the FM Mag 3x168s 700 Lumen mod, for some reason they do not work in my SF M4.
I tried two 168s and then used two A19 spacers, and tried 3x168s, but neither setup would light the MN61 bulb. I also noticed the tailcap did not have that springy push action....like the Pilas are not fitting right?
Hoghead said:J.S. Burly will give you the spring for free, just ask for it.
The free spring goes around the stock spring in the head of your M4.
LuxLuthor said:You just drop it inside the head (light end), and don't put anything on the tail cap end? Even if I manually put the battery against the tailcap, it still does not have that springy push button feel to it. Do you need another spring in the tail cap end?
