wptski said:Okay, I checked both of my smoke alarms. One had a alkaline which measured 8.2V, 60% on a ZTS battery tester and self tests fine. The other alarm had the MAHA PowerEx Ni-MH 9.6V that has easily been installed for a month, reads 10.1V and self tests fine too. I'll make a note of how long this battery lasts.
mina:mina said:I'm wary of using rechargeables on my fire alarms. It'll be interesting to see if rechargeables can be a reliable alternative in these types of applications.
A rechargeable LiIon seems like a better choice as compared NiMH/NiCD though.
wptski said:john2551:
The PowerEx Ni-MH 9V battery still works with the smoke alarm test button!
markdi said:stay with lithium in your smoke detector.
nimh self discharges too fast
John:john2551 said:Mark,
No offense, but i spent ~$150 on an Ansmann Energy-16 charger less than a year ago & i WILL get good use out of it. I don't care if i need to charge them up ever 1-2 weeks! I will use this charger often! I've bought other "gadgets" in the past only to sit on a shelf for years. I'm not going to let that happen with this.
Regards,
John
john2551 said:Mark,
Regards,
John
A flashlight is a "reliability critical device" when used by law enforcement too and I'm sure they use rechargables as they do in their radios also!Handlobraesing said:That's a lousy excuse for using NiMH batteries in a smoke detector, which is considered a rather reliability critical device. Smoke detector battery lasts a while and a really long time for an AC powered model with 9V battery backup for power outages.
wptski said:A flashlight is a "reliability critical device" when used by law enforcement too and I'm sure they use rechargables as they do in their radios also!
Yes, if something is AC powered with a battery backup, the battery would last a long time! That's a no-brainer.
You always carry spares be it primary or rechargables. Alkalines have been around for a long time, so that's what you get in a emergency kit. Maybe they'll have a car charger for a emergency batteries in the future. As far as Ni-MH not being reliable! This PowerEx 9.6V has been installed since 11/05 at least and I'd call that very reliable. Maybe these small eight cell packs have a much lower self discharge rate than other cells?Handlobraesing said:Yes, but they're used and charged daily. NiMH is not a reliable source of power in standby. You don't see an emergency kit with NiMH and instructions saying "please charge once a month" do you? Backup battery on an AC powered smoke detector would not last long at all if the battery has significant self discharge while standby, so for this application, the inherent characteristics of NiMH is detrimental to system reliability.
