Need help finding resistor?
Bravo25
Kansas, USA
I recently puchased some 420 Nm UV LED's, and it has been at least 30 years since I took electronics.
I want to transplant one into MN02 lamp assembly. Can anyone one tell me what resistor value I would need to drop 6.4 volts to about 3 volts? Also what would the smallest resistor for this application be, and where might I find it?
Thanks
Chuck
Bravo25
Kansas, USA
Thanks Flash. That helped me find the proper Ohms, but what about the milliamps? Won't LED just draw whatever power it needs at a given voltage?
How would I find out what milliamps this particular LED requires to run efficiently?
Flash_Gordon
NC USA
You will need some info on the LED you are using. You should have a vF value and a mA (or max mA) value.
If you plug those values and your vBatt value into the calculator it will give you the resistor value in ohms and the resistor rating in watts.
In your example with a vBatt of 6.4, a vF of 3 and say 50 mA, you would use a resistor of 82 ohms ¼ watt.
Resistor should be easily available at any electronic supply house.
Doug Owen
No, current will not magically regulate if you specify the voltage (unlike most other devices including light bulbs). You need to think in terms of current.
In general, LEDs give more light for more current, but you get less 'light per miliamp' as you go higher and higher. There's also, of course some other limits. In general you want to limit current in 5 mm parts to no more than 20 mA. Their lifespan is short enough at that level, no need to kill 'em even faster.
Doug Owen
MrAl
New Jersey
Hi there,
Some good advice from Doug...the smaller LED's usually take 20ma max.
Here are some formulas to help calculate the correct resistor value:
R=(Vs-Vf)/I
P=R*I*I
where
R is the value of the resistor (ohms)
Vs is the source voltage (battery or other voltage in volts)
Vf is the LED forward voltage drop at specified current in volts
I is the current flowing through the LED and resistor in amps
P is power in the resistor in watts
You would first calculate the resistor value R and then calculate the power P
to make sure your chosen resistor can stand the total power when the circuit
is energized.
Example:
You want to power an LED that needs 20ma at 3.3v from a 6.4v power
source.
Here,
I=0.020
Vs=6.4
Vf=3.3
using R=(Vs-Vf)/I we calculate the resistor value:
R=(Vs-Vf)/I
R=(6.4-3.3)/0.020
so R=155 ohms.
A close standard resistor value would be 150 ohms.
Now calculate the power from
P=R*I*I
P=150*0.020*0.020
so P=0.060 watts approximately.
Doubling this to be safe we get 0.120 watts, which is less than
an 1/8 watt resistor so we can purchase a 1/8 watt or higher resistor
of 150 ohms.
There is something beautiful about an LED and series resistor circuit, in that
it's so simple yet it provides a very reliable light source.
There are also other alternatives if you find your 6v power source varies quite
a bit and the LED brightness changes too much.
A quick sensitivity analysis will tell us if our LED brightness changes
too much with input voltage...
Using the formula
I=(Vs-Vf)/R
we calculate two currents, one with normal voltage and one with
voltage 0.1 volts less than normal:
i1=(6.4-3.3)/150=0.02066667
i2=(6.3-3.3)/150=0.02000000
If we then calculate the percentage differences in both voltage and
current we get:
1-6.3/6.4=0.015625
1-i2/i1=0.03225806
Examining these results shows that for a change of 1.5 percent in voltage
we get a change in current of about 3 percent, which means the current
change is twice that of the voltage. We'd have to be careful if the voltage
changed too much. Also, other calculations show that if the voltage
is very close to the LED's forward voltage (Vf) the sensitivity is even
worse (could be very sensitive to voltage changes) so we may not even
be able to use a simple series resistor for some voltage sources unless
we could also tolerate a very drastic change in current (and thus brightness).
Luckily, this isnt the case with a 6.4v source and a 3.3v LED.
Oh yeah, BTW, "Welcome back" :)
Take care,
Al
