ArmyTek
Page 1 of 2 12 LastLast
Results 1 to 30 of 50
Thread: Review: Amilite Neo T3 (beamshots added 1-14-06)
    Default Review: Amilite Neo T3 (beamshots added 1-14-06)
    I got a package from Korea yesterday. All I can say is WOW. This light is awesome. All sorts of brightness and throw in such a little package.
    The Amilite Neo T3 is an alluminim single celled luxeon flashlight from Korea. It takes on CR123a and uses it very well. It is very bright and the company says it will last for 1 hr 30 min. Not too shaby for as bright as it is.
    When I say this light is tiny I mean TINY. Its much smaller than all but two of my lights which are made to be put on a keychain and are much much more dim. Here are a few pics of it next to other lights I have.
    It fits in the pocket really really nicely. I do thing that they edges of the machined ridges are a bit sharp but thats no biggie. It twists very easy and turning it on with one hand is really simple.
    It came with a lanyard and belt clip. Neither of which I have much use for so I attatched the lanyard you see in the pictures. I didn't have much time for many beamshot(I'll try to get that done in the next couple days.)
    Out put is really nice. It is brighter than my Fenix L1P and Dorcy Super 1 Watt. It the hotspot is bigger than the Fenix and it comes in really handy when I check the house for monsters at night.
    I have one gripe about this light though. There is the smallest about of anodizing missing from one part of the light. This is actually alot less than what some have seen so I won't complain. You can see it in this picture.
    The finish is a HAIII or type III hard anodizing. It is a bit shinier than I was expecting but it feels like it would hold up really really well.
    I don't really have much else to say about this light. Its really bright, small, and great quality. It will work very well as a back up light or just a light to look at.
    And to finish it off, here are just a few more pics.
    Edited to add: I got it from www.amilite.co.kr and it was $72 plus $12 shipping.
    clipse
    Flashaholic* Grubbster's Avatar
    Jan 2005
    Danville, KY
    Default Re: Review: Amilite Neo T3
    Looks like a great little light. Nice pics too! Let us know how it does, and don't forget those beamshots!
    Cool Re: Review: Amilite Neo T3
    I have dropped mine on a peice of metal, and it didnt scratch the least bit. I am not a fan of the beam-quality though. Yours seems to have some HA3 on the head threads, but mine has none at all.
    -David
    Also, yours doesnt have an O-ring between the lens and the Bezel does it?
    -David
    Flashaholic Ras_Thavas's Avatar
    Nov 2005
    Virginia
    I used a black sharpie marker to color the ring where the HA3 was missing.
    Oct 2004
    Flushing, NY
    Nice review . Did the shown little lanyard come with the light? also, I hope this isnt too irrelevant, but whats that inside your trigger guard on your 1911?
    Flashaholic* chrisse242's Avatar
    Dec 2003
    Germany
    Quote Originally Posted by Mags
    Looks like a point socket for a ratchet, I wonder what it does there?
    I made the lanyard. The Socket is there to prop the gun up.
    Sep 2005
    SE Wyoming
    I agree there is a lot to like about the Amilite T3; Brightness, size, run time, beam shape, finish, and decent ergonomics, for its size.
    I am running mine on standard RCR123A rechargeables, with no apparent ill effects. Time will tell if this is truly reliable. I put a small diameter rubber o-ring over the positive battery button. This allows a cirgar grip activation technique to be used, when the two pieces are screwed down the the correct point. For me, the Amilite T3 is a nice backup light. Out at night, mine is most often paired with a belt carried Gladius on EDIT>3.0V<EDIT regulated RCR123As, and/or C3-BK+P91 on unprotected 17500s, depending on planned activities.
    Minuses:
    Besides the frequent complaint about missing HA-III below the o-ring, the edges of the lanyard loop are razor sharp. Put most anything other than metal in there and give a tug...The light will cut plastic, nylon, or even kevlar instantly. Likewise, the body machining is quite sharp. This makes the light uncomfortable to carry up against the skin, or pressed against the skin thru a thin layer of clothing.
    All in all, a useful addition to my compact light arsenal, and a worthy competitor to my Surefire KL4 + Vital Gear FB1, for daytime primary or evening backup/concealed carry.
    NextLight
    from good, to better, to ...
    Modulated Moderator Radio's Avatar
    Oct 2005
    The Land of Baked Beans and Red Sox
    How in the world did you get an RCR123 in there? have to shake mine just to get CR123's out because it's so tight. What model or brand are the rechargeables? Did you have to remove the plastic on the outside or in some way modify the light os battery? Thanks for the info.
    Carrying a firearm for self-defense gives you great power. Society expects great responsibility from those with great power.
    Sep 2005
    SE Wyoming
    Quote Originally Posted by Radio
    Only standard unprotected, unregulated, RCR123As fit. I have two from Lighthound (Marked LC 16340 700 mAh) that fit easily. And I have 6 of 10 from Dae (white top inulator that looks like a fat "+" sign, marked LIR 123A 3.6V 800mAh) that barely fit. But, most DO have to be tapped out, as you say, unless modified.
    ONLY for use in this and similar lights with no insulator or moving parts in the bottom assembly, one could cut the insulating jacket off the bottom portion (1/8-1/4 inch works for me) of the cell for a better fit. It is still safe to charge these in a Nano charger IMO, but one needs to use care with putting it in other light bodies and probably some other chargers.
    NextLight
    Oct 2005
    Thanks for the very detailed explanation, yes mine are all protected cells and do not fit, might get a couple of unprotected just to use in the AmiLite since I Luv free lumens and the AmiLite Luvs batteries!!!
    Oct 2004
    Flushing, NY
    I also want to add that the missing HA in your picture seems to be quite a large amount. I am pretty sure Amilite would replace that one for you.
    I would suggest asking for a replacement, too. Mine came with no problems at all with missing HA3. For about $70, these things should be taken care of. Great light!
    Orb Raw NS (UWOJ), VB-16 (Fourth Edition SSC), Fenix L1T 2.0 Rebel, MTE C2 70601, Liteflux LF2 (SSC P4), Fenix L0P-SE (SSC mod), Amilite Neo T5, Peak Caribbean (Seoul), Jetbeam CL-E 1.2, Fenix L2P (Nekomane CR2 mod), JIL CR2 1.3 (Up), Sam's Element, Streamlight ProPolymer Luxeon AA.
    Quote Originally Posted by onthebeam
    I'm not that concerned about about. A black sharpie later and you can't tell. Besides, its not worth the hassle to send the light back to Korea and wait for them to send one back to me. I'm perfectly happy with the little guy.
    clipse
    Clipse,
    Nice review, excellent pics and beautiful lanyards! As Doug mentions in Flashlight Reviews, the Neo T3 is remarkably bright. In its size class I have found it to be brighter than any commercial light other than the HDS and Lioncub, and it is somewhat smaller than those lights. Despite its relatively short runtime the T3's beam is so superior in terms of brightness and pattern that I'm seriously considering it as a replacement for my Peak Carribean (pocket version).
    Trouble is, the Peak is even smaller than the Neo, very bright (though not equal to the Neo) with longer runtime and almost small enough to be a keychain light. It is wonderfully compact. I've been alternating between those two and finding it hard to make a decision.
    Brightnorm
    Flashaholic* Trashman's Avatar
    Mar 2005
    Covina, California
    Quote Originally Posted by clipse
    clipse
    The photo showing the "missing" HA3...is that with the light turned all the way off, or is the body screwed toward the on position to show where the bare spot is?
    Quote Originally Posted by Trashman
    It is screwed so the light is off. Actually screwed it a bit further than usual just to show off the missing HA3.
    Beamshots!!!
    I don't have the best camera for beamshots but it'll give you an idea. All beamshots were taken about a 6 feet.
    Dorcy Super 1 Watt 1x123 (left), Amilite (right)
    Streamlight Jr. Lux (left), Amilite (right)
    Fenix L1P (left), Amilite(right)
    That was a bit deceaving so here is the same pic only in negative form.
    Streamlight TL2 LED 2nd gen (left), Amilite (right)
    Surefire G2 (left), Amilite (right)
    clipse
    Oct 2004
    Flushing, NY
    Nice beamshots. It seems the Amilite has a rather yellow tint compared to other LED lights. sidespill looks HUGE.
    The amilite does have a warmer tint but this pics kinda exagerate that. The side spill is little bigger than most of the other lights and ALOT brighter than the other lights.
    clipse
    Cool Re: Review: Amilite Neo T3 (beamshots added 1-14-06)
    nice beamshots, but does yours have an o-ring between the lens, and the bezel? By the way, do you think it is waterproof?
    -David
    Default Re: Review: Amilite Neo T3 (beamshots added 1-14-06)
    No, mine doesn't have an o-ring between the bezel and the lens. I don't see why it would unless to keep the lens from getting scratched. There are two o-rings. One between the lens and the head, , and one between the head and the body. Both o-rings seem to pretty good. AS far as waterproof, I dunked in it a glass and nothing happened. I wouldn't take it diving or anything like that but there shouldn't be anyreason to be concerned about water seeping in unless you turn it on and off under water.
    clipse
    well, my pelican m6 has a o-ring between the lens and the bezel. Maybe water could kreep through the space? There has to be a reason that they do that.
    -David
    Quote Originally Posted by cheapo
    -David
    It would have to make it by the o-ring between the lens and the head first.
    clipse
    I am talking about the water going around the lens, then into the reflector.
    -David
    Flashaholic Ikonomi's Avatar
    Sep 2004
    Houston.TX.USA
    That is some serious spill light from the Amilite.
    "There's nothing amazing, just the norm."
    Flashaholic* FirstDsent's Avatar
    Jan 2006
    Columbia, South Carolina
    Look again guys,
    Mine has an o-ring between the bezel and the lens, but it is clear! I had to stick my fingernail in there to be sure. The o-ring between the head and bezel is also clear. I couldn't tell you why.
    Also, for clarity:
    when the head is screwed all the way on, the bare area doesn't show on mine, however the light is ON in this condition, so I have to screw the head off a turn or so, thus exposing the bare area. It should be anodized, but maybe the anodizing has some build that would cause an interference fit. Does anyone know if this is the case?
    Bernie
    maybe the HA3 would cause the threads to increase size slightly and then causing them to be gritty because of the roughness of HA3????
    -David
    Jan 2006
    The bezel threads are HA III anodized and theyre as smooth as butter. Quickbeam mentioned a problem with the anodizing on the sample that he got. Like his, mine is missing the HA III from the inside corners of all the circumferential grooves. The bezel threads are perfect though.
    -Strange
    Aulthough imperfect, I love my Neo T3. It is my EDC. I have ordered a McR20 reflector for it. I understand that it is a drop-in perfect fit. It will probably lose some throw, but I use mine mostly inside at work, and a more evenly spread light will suit me better.
    Bernie
