link doesn't seem to go to anything related to flashlights...?rikvee said:Here's a link to G&P's website
Yes, I have. There's no difference in markings (there never is, unless you buy a Diglight USA version, which will say "HP", but I'm sure TradeDigit sent me the brighter lamp.LumenHound said:Has anyone actually got a confirmation from TradeDigit that they are selling the 175 lumen lamp and not the 105 lumen lamp?
Are you sure it's that low? Not 1.1 or 1.2A? I don't think I'm getting more than an hour from my 1400mAh cells.LumenHound said:The high pressure G90 will draw less than 1.0 amps on a pair of rechargeables that are hot off the charger.
Raoul_Duke said:What I would like to know is if I can run any other, higher output, L.A. like the wolf eyes or pila, and specificaly, If I could run the G&P G90 175 lumen L.A. as it uses less current than the P91.
If I can run the G&P G90 105 Lumen L.A. In this 2 cell Protected RCR123 set up, what Lamp assembley should I try next as a Lumen upgrade ( forget runtime )
Here's the correct link to G&P flashlights and lamp assemblies. Incredibly, they list only one "level" of xenon lamp, almost cetainly the low pressure.mdocod said:link doesn't seem to go to anything related to flashlights...?
NotRegulated said:I haven't used G&P lamps but it sounds like the G90 is like the Surefire P90 and the high-pressure G90 is like the Surefire P91.
Also, doesn't G&P make a lamp that has a xenon bulb and 3 LED's in the reflector?
Paul_in_Maryland said:The only way around the G90's extraordinary efficiency is to assume that currrent is higher when using higher-capacity cells (1000 to 1500 mAh, vs. 750mAh for RCR123A).
