Just wondering how much extra throw is gained by putting a kt4 turbo head on an M3? Using the LOLA, will the difference between M3 and M3T be dramatic?
Sorry, but what I have is the SureFire M3 and the SF.M6. That said, it's not really a "fair" comparison. . .But, YES INDEED the SureFire M6 does out throw the SF.M3. I like them both as they came from the factory. Enjoy!
The T version with the LOLA outthrows the M3 standard with the HOLA quite dramatically to me. So much so, that I will run the M3T with it's LOLA and a lot more runtime for the job I bought it for. I will probably sell the standard M3.
50% increase in range LOLA/Std head vs LOLA/Turbohead. Narrower beam on the Turbohead due to increased focus. 125 yard range maximum for the std. head and 175 yard range for the Turbohead using the HOLA bulbs (this is all I ever use). Cut these distances in half if you are using the light on a rifle and you close one eye when you shoot (now half the light entering your single eye). I have found that the turbohead is a bit large/awkward to carry and I only carry the regular head with the HOLA bulb.
I don't have the M3 or 3t, but I do have a 9P that now has a turbohoead on it. The difference from the regular bezel to the turbohead was massive. Especially in places with some ambient light. I assume the M3 versus the M3T to be the same or at least very similar.
