Mr.Ted bear , Kenshiro, thanks a lot for the valuable work .Cue, Lips, That Guy, Dynacolt, and everyone else thanks for the comments and the moral support.
Just as Mr. Ted Bear mentioned many changes are done as I am busy writing that post,
1. we have returned to our original stage as far as the Boost feature is concerned-meaning it will be upon demand ,push to Activate , release to Deactivate, this feature is controlled by our written software.
2. Runtime will probably exceed the 200 min
3. Charger, we will have standard Charger + (-) 5 hrs charge time with an option to fire up the units while charging from the mains.
4. Quick release mechanism for RL battery.
5. Both RL/RB batt status indicator.
6. Optional fast charger under development and will be available at a later stage, not for next coming shootout as we have only commenced work yesterday after a long new year break.
7. The IR Push button on Ver1 will be implemented at a later stage on other models.
8. As to Dynacolt question regarding the Flash mode, unfortunately we can not elaborate on that forum how it is done, the only tip that I can give you is, that the devices are software controlled, the lamp life span is reduced (not dramatically) and that feature was requested specifically for an application where the lamp life span becomes irrelevant –emergency cases.
9. IR and other filters are all hinge mounted- Metal coatings or Dielectric pending the application.
10. RL battery eliminator – to operate directly from a car cigarette lighter socket or other 12VDC supply.
There are several other components under developments i.e Car Charger & other features which will be introduced at a later stage.
