SunwayLED
Results 1 to 4 of 4
Thread: How do you change bulb on Princeton Tec 40?
    Nov 2005
    NJ
    Help How do you change bulb on Princeton Tec 40?
    How do you change the bulb on Princeton Tec 40? Maybe I'm missing something, but I can't figure it out. I don't want to break anything. Any advice would be greatly appreciated. Thanks.
    Default Re: How do you change bulb on Princeton Tec 40?
    Quote Originally Posted by G-force
    1. unscrew the bezel anti-clockwise and remove the bulb assembly inside
    2. the bulb assembly is made up of 2 inter-locking parts - the black bottom holder and the silver reflector. The reflector is held onto the holder by 2 nipples.
    Press the reflector just above the nipples and simultaneously pull the holder down. Do the same for the other side and the 2 parts will separate.
    Nov 2005
    NJ
    Thanks lexina! You just saved my back door light from replacement (for now ). I'll be running cheap stock mag-lite bulbs in it. I'm even going out on the edge and trying a 3 cell mag bulb in it first. It didn't and so far it's super bright.
    Flashaholic* pedalinbob's Avatar
    Dec 2002
    Michigan
    I always sing the praises for the Tec 40. It may look boring, but is a real workhorse.
    For cheap bulbs, the Rayovac KPR 113 ($1.50 for 2) give great life, decent brightness and an excellent beam.
    I can often find the 4 cell Maglite Xenon Stars at Home Depot for $2.50, which is a good price. They are very bright and the beam is extra-nice.
    Bob
