Foxfury Scout
Results 1 to 12 of 12
Thread: Tail lights/brake lights on 18 wheelers
    Flashaholic* cratz2's Avatar
    Apr 2003
    Central IN
    Default Tail lights/brake lights on 18 wheelers
    On a trip the other day, I noticed that I could clearly see the red tail lights (not even brake lights) on an 18 wheeler trailer from over a mile away. When I caught up, I noticed that it only had six emitters arrange in a pentagod with the sixth in the middle. When the brake lights were applied, it looked at least twice as bright, possibly even more than twice as bright.
    What are these assemblies using? Are they Luxeons of some sort? I've seen the lights that have about 15-20 LEDs installed, but they were obviously nowhere near as intense per emitter as the ones I'm talking about.
    Any chance someone has a couple of these they'd be willing to sell on the cheap?
    "That's what makes SF so badass... we've got the best flashlights."
    Jul 2005
    illuminationGear
    Default Re: Tail lights/brake lights on 18 wheelers
    I'm looking too - for my RV
    havnt seen any 6-LED though
    these look interesting
    http://www.vehiclelight.com/ledstli.html
    http://www.buytruckstuff.com/s_produ...selcategory=61
    several brands to look through
    the sequential ones are kinda cool - the cop bikes and ambulances around here use them - and certainly gets your attention
    the reality of life... 50% +/- of it will be in darkness(unless you have a light!) dba
    (also EagTac-USA)
    Apr 2003
    Central IN
    Yeah, I've seen the ones with about 15-20 per light, but they are nowhere near as impressive as the ones that are 6/per. I'll try to get a pic if my diesel mechanic friend ever services such lights. It seems like these are mostly on the trailers, not on the trucks though. I saw the initial truck I was talking about maybe 2 weeks ago and since that time, I've probably seen 20 trailers with that type of arrangement, but only maybe 2 trucks with that arrangement.
    Sep 2004
    Ive noticed that too. The full led laced circles sometimes fail in pie shaped wedges.
    Ive also noticed some cars have a full panel of led for the stop and turn signal lights, other cars use just a few leds spaced out a few inches apart and brighter than the panel design.
    Flashaholic Inferno's Avatar
    Sep 2005
    Honolulu, HI
    The big draw for use on emergency vehilce lightbars is that they last longer than regular strobes and draw fewer amps from the batteries. I can't wait until I can get a set of LED replacements for my turn signals and brake lights...
    Simple trauma assessment: Air goes in & out, blood goes `round & `round; any variation is a bad thing.
    Exercise is good for you.
    Flashaholic Bogie's Avatar
    Nov 2004
    Queens,NY
    SF 6P/G2/E2e/E2d/E2DL/E1e/L2/A2-PP(R)/A2(G)/L1(R)/L1(G)/M95/KL4(x2)/KL4(Blk)
    Gladius,Inova X5(R),Microlight(G)
    Costco/HF HID
    *Flashaholic* IsaacHayes's Avatar
    Jan 2003
    Missouri
    They must use spider super flux leds. Check out lumileds.com. That's my guess.
    "the Precious..." iNDiGLo's Avatar
    Oct 2005
    Texas, USA, Earth
    http://www.mesa4x4.com/dynamic/singl...r=LED%20R%20US
    I put these on my Jeep. They're awesome and bright as Heck!!!
    Smeagol: "the Precious..., curse them. We hates them. It's ours it is and we wants it."
    Banned
    Jan 2005
    They are Lumileds Snapleds, not superflux. These are LEDS on a metal frame rated at 75 or 150mA I believe with a big thermal path. I would add another supplier to that list, Grote, I see their products in the stores.
    Semiman
    Apr 2003
    Central IN
    Thanks for all the replies, guys. I tend to make the same 60 mile trip once or twice a week and usually one way or the other, it's dark. In comparing the 6 LED lights to the standard incandescents, the LEDs look visibly brighter from a distance though it could be because the incands have hare more grime build up outside and possibly a bit on the inside.
    Still, I'd like to get a few of them to see how they do in flashlights... I imagine they won't focus as well, and they don't look like they have a particularly wide beam but, that's from behind a lens so who knows...
    Jul 2005
    illuminationGear
    thanks for the clue!
    that's it!?
    http://www.truck-lite.com/webapp/wcs...4035&langId=-1
    click on pic for close up
    TRUCK-LITE MODEL 44 LED
    Most advanced & cost effective LED S/T/T lamp on the market
    Utilizes cold clinching joining process for a more reliable & robust product
    Snap LED array dissipates heat more effectively, resulting in greater light output
    Advanced optics design creates a greater dispersion of light
    Electronics completely sealed in epoxy to resist corrosion & moisture
    Uses standard mounting holes & accessories
    Draws less current, allowing more power for other vehicle requirements
    http://www.buytruckstuff.com/product...y=22&p_gpID=39
    Quote Originally Posted by SemiMan
    Semiman
    (also EagTac-USA)
    Apr 2003
    Central IN
    Yea lebox, that first link might be what I've been seeing.
    I noticed today that a UPS truck had what looked like the same thing but the red cover was more... uh... blending. That is to say, if you just sort of glanced at them, you might not realize that there were six different light sources under the red lens. They also looked like it might very well have been white LEDs under the red lens while the ones I've been seeing and was originally talking about looks like six red emitters and I could easily and clearly see that there are six distinct sources.
