Mike, here's some info on wiring multiple Sharks. The Sharks pictured are early versions without the copper C, but the wiring should be the same.
This is a pic of a Remora controlled tri-Shark mod (9 X Cree in a 3" Delghi head on a Leef neck adapter). The brass shapes are topside sinks I made to help cool the IC and diode.
This is the wiring of the Sharks for use with a pot:
How to wire multiple Sharks to one dimming control:
- Order the Sharks with the on-board pot removed, or remove the pot yourself.
- Locate the three pads under the pot. Viewing the board from the component side with the pads at lower right, you will see that the larger central wiper pad connects to the top soldering hole just to the right. There are two smaller pads under the large pad. The lower right pad connects to the lower right soldering hole, and the lower left pad does not connect to any hole.
- If using a pot, order a 20K log pot. I use these from Digikey.
- Connect the pads of one Shark to the pot. Viewing the pot with the shaft at top and the leads facing you, connect the large wiper pad (or top right hole) to the center pot lead, the lower right pad (or lower right hole) to the left lead, and the lower left pad to the right lead. I find it just as easy to solder to the pad as to the hole. The wires do not pass any current, so I use very thin flexible wire, 30 ga or so.
- The other Sharks are wired to the mother by connecting the large wiper pads together. Any number of Sharks can be wired together. Alternatively, all three pads of each Shark can be connected in parallel, or all connected to the pot.
- If a Remora is used, connect the Remora to one Shark, and again wire the wiper pads together. All Sharks must have the on-board pot removed.
