NEXTORCH
Results 1 to 14 of 14
Thread: task manager won't close non responding program
    Mar 2003
    bay area California
    Default task manager won't close non responding program
    I spend way too much time each day trying to have task manager close non responding programs. I am apparently not the only one having this problem, anyone here have a solution? I'm sick of this. I am so upset over this I'm thinking about going to the insame amount of trouble to purchase an apple computer even though it would take me days and days to set it up.
    when I click end program in task manager, it take forever to close the programs that are not responding.
    Any help would be greatly appreciated
    when you always do what you've always done, you always get what you always got.
    Aug 2005
    Vancouver, BC
    Default Re: task manager won't close non responding program
    If your trying to close them from the applications tab try the process tab
    Flashaholic* Frenchyled's Avatar
    May 2002
    Land of Cheese, Frogs and wine
    I gnerally don't use the task manager in windows XP, but somme freeware that I find much better
    Like what's running
    Or PRCview
    Maybe these utilities can help you
    Dec 2002
    Tennessee., USA
    ME TOO !
    I hate it !
    I wind up having to restart the blasted computer, or just shutting it down.
    Help....
    Are you talking about a Mac or PC? If a PC, here's one solution (do this with caution, especially if you have a critical application that starts up with your PC):
    Identify the guilty program if possible
    1. choose Start - Run - msconfig
    2. choose Selective Startup - Uncheck everything
    3. click Services Tab - check Enable All - check Hide All Microsoft Services - check Disable All
    4. click Startup Tab - check Disable All (most likely they will already be disabled)
    5. click OK
    6. choose Restart
    7. When the PC reboots, click OK and then Exit Without Restart
    Your PC has now been rebooted with a minimal startup and some of your software may not work; you need to begin re-enabling Services and Startup items one by one until the rogue program returns.
    Good luck!
    Best regards, Steve
    SF U2 / Anti-Terrorist Symposium 2005 2006 Editions
    Cats | My Gallery My other car is a Trek Y-50
    Mar 2002
    New Jersey
    What operating system are you using?
    I presume this happens randomly to various programs. Maybe something has a memory leak and you are running out of memory.
    Did you install any new hardware or software when this started happening?
    Maybe the event log would show something.
    *Flashaholic* carrot's Avatar
    Dec 2005
    New York City
    IMO Win2K and XP have the best task managers of all the Windows OSes. I like the program EndItAll2, but not sure it kills everything -- with a bit of searching you can find it for free online.
    Switching to a Mac sounds nice. :P
    [gearcarrot.com] Collector and distributor of (mis)information.
    The Guide to High-End Lights | Flashlight Story Collection updated Sept 28
    CPF Specials | 4sevens | LED Testing | EDCF | #cpf
    Aug 2004
    Chicago
    I'm not sure; are you saying that TM won't close the program, or just that it takes a long time?
    LMU
    Jan 2005
    GTA, ON, Canada
    I find when trying to end a stubborn program, it is much easier to go into the task manager, RIGHT-click the application which is causing you grief and then go the the process, and stop the process directly.
    You do have to be a little more careful doing things this way, though. For example, if a folder is frozen, the process will be 'explorer .exe', and if you close this, the Windows GUI will close, and you'll have to click File...New Task (in the task manager) and manually type in explorer.exe to re-initiate it.
    Hope this helps,
    -Brad
    *Flashaholic* greenLED's Avatar
    Mar 2004
    La Tiquicia
    I'm with Stevesurf on this one. However, I recommend a slightly different approach. Make not of the applications/files listed on msconfig's startup list, look them up on the web if it's not immediately obvious what program(s) they're related to, and then deactivate the suprefluous ones.
    Do you have lots of programs resident in memory? I can almost guarantee most of them are unneeded; don't start them unless you really need them.
    Jan 2005
    North Metro Atlanta, Georgia
    Quote Originally Posted by keithhr
    First things first! If you are constantly having to try and close unresponsive programs then something is defintely wrong! This is not normal behavior for a modern pc. I would suspect that your pc is infected with malware and/or corrupted files. This could also be caused by bad hardware such as your hard drive, motherboard or memory. Please post or PM me more info on your pc: What brand/model is it? Windows version and service pack? What programs are you running that keep locking up? With a better idea of what is going on, you can easily get this resolved!
    Aug 2004
    Chicago
    Quote Originally Posted by greenLED
    This is very true. I remember when I first installed XP Pro on my machine, MS had all kinds of stupid processes running that were not needed, and furthermore created potential security loopholes. I was able to get the normal number of processes running on my computer down from 39 to 25 without any loss of functionality. This also freed up some memory and processing power that was being wasted, allowing my normal programs to run a little faster.
    LMU
    Flashaholic aso's Avatar
    Oct 2001
    NY
    One of the best programs I have ever used is Codestuff Starter . It is a thousand times better than Task Manager at finding and closing unwanted/stubborn programs and services. Best of all it is free.
    ...Darkness cannot drive out darkness, only light can do that...
    Martin Luther King, Jr., Strength To Love, 1963.
    Jan 2006
    in poverty
    try cleaning up your computer with an anti spyware program like spybot to get rid of spyware in your computer. these spyware are ram eaters and slows down your computer significantly. with those out of your way, at least half of excess programs will be gone and your task manager should stop lagging. from there, you can stop those programs that the spybot had missed out before.
    heres a link to dl spybot:
    http://www.safer-networking.org/en/
