For what it's worth, I EDC an Icom IC-W32a, and really like it. It's not all tactical looking like the new Yaesus, but it works really well, and it's an honest dual band radio (ie, two radios in one case, vs. one radio that can tune several bands). It doesn't do all the wideband receive of the newer radios, but it also doesn't suffer from anywhere near the intermod (receiving pager signals 10 MHz away, etc.). If you live in an urban setting, that's very important.
I'm not going to recommend any particular radio (although I did want to get a plug in for Icom, since I really dig their radios). However, I will say this: get yourself to a ham radio store in person, and handle the radios, if at all possible. You may discover that you like the VX7 or the FT-60 much better once it's in your hand, or you may discover that one has a difficult display to read, etc. You might discover that one of the small, tri-band Icoms or Kenwoods feels better to you, or makes more sense out of the box.
There's a lot of value in having a radio that you Just Understand without having to refer to a manual. If you have to study up on how to use it, it's going to be used less, or less effectively, and that would be a waste of money. For what it's worth, the Alincos I've used have had absolutely atrocious interfaces. The one ADI mobile I had was even worse, and I'll never buy anything ADI again (although it was a fine radio, in terms of technical performance). The one Radio Shack scanner I had (a Pro-91) was difficult for me to use, but I think that's because I wanted to use it like a ham radio, not like a scanner.
In general, radios by the same manufacturer have the same interface -- Yaesu is very good about keeping a consistent interface between HTs, for instance. Learn to use one Yaesu, and you'll have no trouble learning the next Yaesu. I had that experience going from an FT-50 to a VX-5 to a VX-1 and VX-2. Likewise, Icom is pretty consistent, and I didn't have to research much between different HTs. I've only ever owned one Kenwood (TH-D7A(g)), so I can't comment on their interface consistency, but I personally don't like the interface of the Kenwood as much.
Anyway, my main point remains that I think it's really worth getting the radio in your hand before you plonk down your cash (just as you'd want to do with a flashlight, or a multitool, or a handgun, or a knife, or whatever). If your first reaction is, "this thing feels weird" or "this thing is hard to use," that's unlikely to change a whole lot over your years of ownership. I've found that both negative and positive reactions tend to get stronger, but they don't tend to reverse. Obviously this isn't a hard and fast rule, and you're not the same person as me.
[edit] Also, if you're a member of ARRL, they have all their radio reviews available as PDFs online. That's a tremendous resource, and to my mind is worth signing up with ARRL for at least a year just to get that. Their reviews aren't always the best, but they're usually pretty good, and they always have good data in them.
Good luck with whatever you get, and good luck passing your test.
73 de N7DCU
