RMSK, Inc.
Page 1 of 2 12 LastLast
Results 1 to 30 of 40
Thread: Best Butane Lighter
    Au Best Butane Lighter
    I am looking for the best refillable butane lighter. I am a zippo man but need a butane lighter. I want a lighter that will last forever, and will be afraid to lose it. I have tried several of the ones they sell at smoke shops and they all stop working properly after a while and or heavy use. I need a tank of a lighter, and I am sure I'm not the only one on here. Hopefully someone knows their lighters.
    *Flashaholic* Flying Turtle's Avatar
    Jan 2003
    Apex, NC
    Default Re: Best Butane Lighter
    I've also tried many kinds and they always end up leaking after a few months. I think the one that lasted the longest was made by Imco (Austrian company). It was refillable, had a clear window around the fill port on the bottom, and used regular flints. Seems like it was model G77 or something similar. The body was plastic with an etched outline of a pipe on it. It also was pretty cheap (less than $10). Been meaning to look for another, but those 3/$1 disposables are so easy.
    Geoff
    *Flashaholic* B@rt's Avatar
    Nov 2001
    Land of Tulips and Philips
    Thumbs up Re: Best Butane Lighter
    Sarome SJ series.
    Milled from a solid block of alu (no separate gastank ), flint ignition.
    BART
    Flashaholic bruner's Avatar
    Oct 2005
    North Central Pennsylvania
    Strange, but my experience has shown that butane lighters (which use rubber gaskets to retain fluid), always fail over time.
    I think your best bet is to look for a flint ligther that uses regular lighter fluid.
    My best performers are antique lighters. If you click on the "lighter" link in my sig, my colibri lighters (German made, third and fourth from the bottom right corner) retain fluid longer and are more reliable than all the rest. I dislike zippos the most. They are terrible at retaining fluid... Ebay is a good source for such toys...
    Dan
    'Tis the gift to be simple.
    Jun 2005
    Western Massachusetts, USA
    I've got both a Vector KGM butane lighter ($85) and an EMS butane lighter ($45) I recieved as a gift. They are both very good lighters, but I like the EMS better because the platnium wire heats up much faster in it than the Vector, which takes a second or two and may not actually heat up at all if the butane flow is adjusted too high, making the EMS much better if you are expecting to be in a windy situation. Of the two, I carry the EMS every day, and the Vector when I am dressed up and need a lighter that looks classier.
    Flashaholic* JimH's Avatar
    Apr 2004
    San Jose, CA
    A second vote for the Vector. I own a Vector Gear. It has never failed to light on the first strike in high winds or at 8500 ft altitude.
    Jim - Have lights, lead, and steel will travel
    The heck with runtime. I just want to hold the sun in my hands!! Brighter is Better!
    Flashaholic* Frenchyled's Avatar
    May 2002
    Land of Cheese, Frogs and wine
    YEah...another vote for the Vector Gear !!!
    2 month without recharge it, never failed, more than one year used it.
    Check out the Atoll Robusto Rugato at famous-smoke.com. Very sturdy. I have a couple and they're currently my favorites - and they're affordable. One of them has been in my car for about 5-6 years. Still works great. Large brass tank is a bonus.
    The Old Boy is a similar design. Not sure where to get one but google should turn up a few.
    If you have money to spend, the ST Dupont Ligne 2 is great. I've had one since 1984 and it still looks/works like new. The palladium is a great and durable finish. The silver, gold, or Chinese Laquer ones will show more wear if no case is used.
    There are a few other great ones out there but I don't have any direct experience with them. But, if longevity is important to you, go with flint/flame lighters rather than torch types. Even the best torches like the original Blazer and the ST DuPont Xtend will plug up if you use them frequently.
    Thanks all for the replies.
    I have been looking at the vector, can you guys that own them tell me how long you have owned them, and if they have ever failed yet?
    Thanks.
    Nov 2001
    Crazy Re: Best Butane Lighter
    After owning a number of turbo/jet flame lighters I went back to the normal flame ones. the turbo/jet ones are very picky about the butane they use, and even than they tend to clog up after a while. Electronics (the piezo element) are also much more prone to failure as an old-fashioned flint ignition.
    I'm an avid smoker and I'm using my lighters a lot , so my usage is probably heavier than average. (Self rolled cigs won't keep burning if unattended, so almost every cig is lit a couple of times...)
    BART
    What about the PB207? It comes up in pretty much every thread about lighters. I got a cheap canadian tire knockoff but it's still feel pretty solid.
    Quote Originally Posted by eart
    Something we all have to learn on CPF is that posting just a model number is not helpful. Not everyone knows what we are talking about. Please provide the manufacture and a link if possible.
    Flashaholic* greenlight's Avatar
    Aug 2004
    chill valley
    How about a flashlight mod or a solar cigarette lighter?
    Quote Originally Posted by hogx1
    I hope you don't take it the wrong way, but the very first link on google leads to the right hit: http://www.thetoolwarehouse.net/shop/BLZ-PB207.html
    Actually just 5 minutes ago, my coworker used the canadian tire knockoff i mentioned earlier as a make shift soldering iron. Heat up a paperclip till it's red hot and resolder a bunch of contacts on a wireless usb nic. Nifty. This is the one I got http://www.solder-it.com/at2056.asp
    *Flashaholic* bwaites's Avatar
    Nov 2003
    Central Washington State
    I have a Solo like this one:
    http://www.elighters.com/solo-lighte...-lighters.html
    which I like, but haven't had long enough to get an impression on durability, refills, etc.
    This one is cool and even has an LED!!:
    http://www.solder-it.com/MJ-280.asp
    Bill
    Only a virtuous people are capable of freedom. As nations become more corrupt and vicious, they have more need of masters.
    Benjamin Franklin
    I have several PB207s. They seem to last the longest of the torches and they're rebuildable. Still, they plug up after a while. I've rebuilt them following instructions from the Cigar Weekly forums and they seem to work (usually for a shorter time than a new one).
    I do like torches, though, so I've taken to buying the $7.00 Blazer knock offs and refilling them a several times before tossing them.
    Oh, yeah, it's important to use good fuel - triple or quadruple filtered. Prometheus seems good. Ronson is guaranteed to plug up a torch faster than anything.
    I use a Z-Plus torch lighter that fits into the zippo body. Works great, no problems, and inexpensive. You should be able to find one for under $15, just do a Google search, I got mine off eBay. I use mine for burning the ends on paracord lanyards/fobs. I've used a couple of different brands of butane and it worked fine with both(Zippo and Ronson).
    Flashaholic* Yooper's Avatar
    Nov 2005
    Upper Peninsula of Michigan
    I bought a Colibri to take with me on a ski trip. It wouldn't work at my condo at the base of Steamboat Springs, about 6500' I think. I'm disappointed.
    Is there a good online vendor for the Vector Gear?
    The only Colibri that I have owned that is almost decent is a table top one. I would not recommend the company. Very over priced, and low quality.
    I think I am going to try a vector gear and also have heard good things about the old ronson veraflame. Going to see if I can get one from ebay.
    Nov 2001
    Wink Re: Best Butane Lighter
    The Ronson Variflame is a very good lighter, (I have 2 ) but IMHO the Sarome is much sturdier.
    You can't go wrong with either of them though, they are both as basic as can be, so not much that can go wrong.
    BART
    Yeah, the old variflame windlites are excellent. Big tank on them and , if you've got one that doesn't leak, last a long time on a fill. I had a sarome sj and it is also a fantastic lighter (is yours HA3'd yet Bart? PICS Please). I did find the saromes a little small and my hands aren't that big. There is also an old sarome "gas" that is very high quality. It was part of a promotion from RJ reynolds many moons ago (30 years ago). I managed to pick one up in like new condition on ebay. The variflames are extremely wind resistant for a butane, traditional flame lighter.
    I do agree with Bart, the torch type /piezo lighters really dissapointed me in terms of reliability. I also wouldn't buy a colibri on a bet. To be honest, every single lighter I've picked up, when compared to the build quality of the sarome sj and the "gas" and the old ronson, have just looked VERY cheap. I nearly bought a vector "gear" until I picked one up. It just feels cheap as well.
    Pipe smokers go on and on about Old Boy lighters. I'd imagine they are one of the few high quality lighters left and they are priced accordingly.
    I'd really like a titanium lighter and I'm surprised that the only model available is a Zippo. 70 dollars for a little Ti box with a flip lid is silly. Perhaps sarome will see the niche and make something nice in Ti.
    Titanium flashlights are like solid gold radial tires
    Sep 2005
    Michigan, US
    Quote Originally Posted by xochi
    I assume you're talking about the IM Corona Old Boy. I have an IM Corona Double Corona cigar lighter and it is definitely the nicest lighter I own. (BTW, sorry for the ridiculous font on that second link...)
    I've had it for 7-8 years and never had a single issue with it. Just fill it with good butane and replace the flints as needed. While it is neither windproof nor waterproof I would say does qualify as "built like a tank." I believe it is machined out of a solid block of brass, with the fancy shell put over the top of that. I "lost" mine once when it fell into the lining of a little-used sport coat with a hole in the inside breast pocket. When I found it about a year later it was still full and lit on the first strike.
    The IM Corona's are made in Japan and are apparently marketed by Savinelli in the US. Not sure about other markets. I was unable to find a IM Corona Japanese site or other official homepage...
    Quote Originally Posted by Yooper
    I had a Colibri before I got my IM Corona. I did not abuse it and used the recommended butane but nonetheless had nothing but trouble with the thing. Went back for "repair" twice. In the end I simply could never trust it to actually work on any given occasion. The tobacconist sold me my IM Corona at cost to make up for the trouble I had with the Colibri... I think he eventually stopped carrying the Colibri lighters.
    Nov 2001
    Popcorn Re: Best Butane Lighter
    There have been some delays, but I'm expecting the body back soon.
    I'll post pics when I have it.
    BART
    Oct 2005
    USA. _ MA
    Ok sorry for the bad picture ... Here is 2 " china " lighters. the silver one is also a 1 LED flashlight blue tint US$ 5.00 at HoneyFarms...and the Black one is WALLMART US$ 8.00 whaterproof light.
    they work well. I don't smoke and I just use for other tasks.
    so far they are ok. the silver one has a GREEN flame and the BLACK one has
    blue flame. for what I paid they are ok...
    M.TEX
    Costco has the Leatherman Supertool with the china lighter pictured in M.Tex's post (along with some binoculars). I leave them in my BOB for the car. The lighter is decent enough.
    I got a Vector after seeing so many posts about it. Its got a nice solid feel to it. however, its not as nice as i thought it would...especially considering the price. I usually have to double pump to get a flame...and thats after its lit up earlier in the day. my old rebadged eddie bauer colibri from target works first hit more often than the Vector. i'll prob hold on to the vector...just because...but still it is a little dissapointing.
    Flashaholic* SJACKAL's Avatar
    Jun 2004
    Singapore
    Quote Originally Posted by B@rt
    Man, that phrase sometimes get you framed by some nonsmokers whom sees and treat smokers as criminals or drug addicts. You know, with all the anti smoking campaigns. I am a smoker too and I have to admit that I am interested in lighters, cigarete rollers, boxes and stuff. Have you try Rizla products?
    As for lighters, torch style lighters usually don't last long. I end up with zippos anyway.
    Well, I seem to have broken the button on my Z-Plus torch lighter. If I fiddle with it, I can get it to light, but something is definately broken or worn out with it. I've probably put it thru more use making my lanyards in the last several months than the average person would use it over a few years. So for $12 I think I got my moneys worth. I tried another torch lighter I found in the sporting goods section at wally world, but I think it has a pressurization problem as it's hard to light and doesn't want to stay lit no matter what I set the +/- dial on. I use premium butane so I doubt that's a factor. I'll probably just get another Z-Plus.
    Flashaholic* cyberhobo's Avatar
    Oct 2005
    USA
    Thumbs down Re: Best Butane Lighter
    I purchased a Lenk from Lowes hardware. It lasted less than two months. It is exactly like the MJ-280 Turbo-Lite (standard model). The Piezo electronic ignition system is what failed. No way to fix because it's located within the fused plastic casing.
    Link for reference: http://www.lowes.com/lowes/lkn?actio...280&lpage=none - DON'T BUY THIS MODEL, IT'S JUNK!
    "Battle Speed Hortator"
    I have the helios lighter from brunton. Its very well made, waterproof, locks closed and has an adjustable flame. You can get it for about half that price if your lucky. See here.
