Impyboy
How could you tell if the diode has blown?
recently, my leadlight started playing up by suddenly turning off while pressing the button. after a few clicks, it would come back on.
initially, i thought the switch was faulty.
but today, it's had it's last day.
i've taken it apart to test the switch by shorting the two contacts at either end of the switch. it worked momentarily, but then it wouldn't come back on again.
so now that i've eliminated the possibility of a faulty switch, i need to find out where the fault lies. how can you tell if it's the diode, or some other component on the PCB?
many have experienced fluctuations in their beams, but i've never had any history of any fluctuations. i've always had the pot turned to minimum to prevent killing the life of the diode, so i don't think it's due to over powering the diode.
does anyone have any suggestions?
warrenty has been void as i've taken it apart already
thanks
thanks
