HDS Systems
Results 1 to 13 of 13
Thread: Household reflectors?
    Default Household reflectors?
    If i took stainless steel bowl, poked a hole in the bottom and put a bulb through, do you think this would throw longer than say a standard mag reflector?
    "you carry an umbrella if there is a 50% chance of rain, right? Well, there's a 100% chance of darkness tonight." -saunterer
    Default Re: Household reflectors?
    NO!
    Flashaholic* LEDcandle's Avatar
    Aug 2005
    Mushroom S'pore
    Haha... admittedly, the thought had crossed my mind but no way, no throw, but you'll get decent flood that is more or less contained and projected "forwardish" (of sorts), although there will be light loss as the bowl material is nothing like a reflector and is not designed in anyway to collimate light forward.
    if you polish the bowl to a mirror finish
    i would definetly mirror finish the bowl first. not that hard. and i have one that seems to have a pretty good shape. hmm it just got me thinking =)
    It depends on the shape of the bowl.
    But it might be more productive to start with a really big reflector. Ask a local theatre if they've got any old stage lights they're going to trash. Theatres are notoriously poor, so it's a long shot. But if you had asked me 6 months ago, you could have had 10 reflectors out of 8" ellipsoidals to play with.
    The only large parabola-shaped household object I can think of is a satellite dish.
    Flashaholic Danintex's Avatar
    Jul 2005
    New Braunfels TX
    With aluminum foil on it! That would also smooth out any artifacts.
    If it smells too good to be true, you probably aren't at home...
    Aug 2005
    Mushroom S'pore
    Alu foil just creases too easily and it won't be possible to lay it out nicely in a bowl. It doesn't reflect THAT well either... :P
    Flashaholic Templar223's Avatar
    Nov 2005
    Champaign IL
    Quote Originally Posted by Flakey
    I had to giggle!
    Seriously though, I had a cheap 3-D yellow ray-o-vac light that was hanging and the batteries leaked big-time in the garage (I never realized how much liquid is in an alkaline battery!). Brought it indoors and washed it out and the caustic stuff had dissolved the aluminized reflector stuff off the reflector.
    I needed a flood light anyway, so I:
    1. Sprayed photo mount spray (basically aerosolized rubber cement) onto the reflector face.
    2. Glued the shiny side of a piece of aluminum foil to the face, leaving the dull side exposed.
    3. Trimmed the excess Al foil away.
    4. Put the light back together and viola!
    One "flood" light for working in tight spaces.
    Sometimes a fella just doesn't want 800 lumens (or even 60) of light!
    John
    Quote Originally Posted by Templar223
    I had to giggle!
    John
    wonder how silver leafing a reflector would work?
    *Flashaholic* andrewwynn's Avatar
    Apr 2004
    Racine, WI USA
    what he said about sattelite dish. Bowl will likely be spheroid or possibly elliptical but very long shot.. I just saw a 'mythbuster' where they took an 8' sattelite dish to make a 'death ray' by putting on about 6400 1" squares of glass mirror.. that worked exceeedingly well.. and i had the immediate thought of making a mini deathray by using a direct tv type dish and maybe polishing and chrome plating.. but it could be a fun project to make a super-focused LED light.. the neat thing about the way those small dishes work is that the focus is off-center so there is no obstruction from the arm!
    building a parabola is not tragically difficult.. a very simple formula for a parabola is y=nr^2.. figuring out the focus beforehand is a bit more tricky.. the 'n' is just thrown in to be able to adjust the depth 'cause r^2 is a pretty deep parabola with a very short focus.. n would typically be a very small number like 0.1 or maybe even less. You could build something out of foam blocks or balsa wood.. easy to cut to make the frame.. than put some flexible ribs.. maybe copper or brass strips to make the basic frame.. else with just a bit of excel work you could figure out the exact angle and distance to make vertical blocks of various heights to attach standard sized flat reflectors, say 2" square reflectors on a 1" post.. about 60-100 of those and you'll have a pretty killer big reflector.. could probably shine a single 3W led a mile... imagine what a mag100 would do!
    -awr
    Regulated hotwire 'the hotdriver' also for Surefire M6 • 3-level high-power LED drop-in for mag. the 'BAM!' click here
    I have disabled PMs.. use the 'email' link instead!Genesis 1:3 And God said, "Let there be light," and there was light...
    John, Rayovac has some of the best customer support in the industry, in case you ever want the throw back: http://www.popularmechanics.com/home...n/1276716.html
    That kind of service puts many premium brands to shame.
