Literator
Do those of you who have a JIL Intelli have a spring at the bottom of the battery tube? I see nothing but a little nub on the bottom. What made me wonder is that I've been using an RCR2 that I think I bought from Lighthound. It works fine. I recently bought a couple of regulated RCR2s from AW. They are about 1/8" shorter than the others, and I can't get them to work. They aren't long enough to make a connection.
With the Lighthound RCR2, I get the light to come on just about at the point where it stops twisting, since it's on as tight as it can go. There's no force, but it I had to go any further, there would be.
I put a small piece of spring in the bottom of the light, and the regulated RCR2 worked fine, except whenever I turn the light off and tip it upside down, the spring contacts the battery and the light turns on by itself. If there is something (a spacer? spring??) in the bottom that fell out, tell me what should be in there, and if there are any suggestions about where or how to get what I need to replace it, that would be appreciated as well. Thanks!
--Bob
--Bob
