greg_in_canada
(See post #29 for the measurements on my "fixed" L0P.)
The light: it is smaller than I expected. Even though I knew it is a bit bigger than the Arc AAA, the size still surprised me a bit. I've been carrying it in my left front jeans pocket all day, along with my Arc AAA and I don't really notice it. So I don't forsee any problem once I carry only the L0P
The fit and finish: the machining and anodizing look very good to me. The sharp edge of the notch for the split ring is the only minor problem. The knurling is a bit too smooth but some may prefer it that way. Hopefully the anodizing will hold up to being carried in my pocket with my coins. My Arc has survived 1.5 years in that pocket with only a bit of wear on the knurling on the head. The body has been protected by some clear heatshrink tubing, which I intend to do to the L0P also to protect my teeth when I mouth it.
One hand operation: the light is easy to operate one handed. Almost too easy. I pulled it out of my pocket a couple of times today to find it on (on low). It may be I didn't turn it off far enough or the head may have turned while I fished around for it in my pocket. [Feb 16 update: I have been giving it an extra 1/2 turn in the off direction before putting it into my pocket and haven't had it come on while fishing it out. So problem solved.] Turning it to medium takes more force and to high even more. So I don't think it would ever accidentally get turned on to medium or high. There is a fair bit of rotation between low and the o-ring being visible (1 3/4 turns) so you can turn it off a lot if necessary. If it still comes on accidentally I may try the teflon tape trick that was mentioned in a different thread.
Now for some numbers:
o-ring visible to low: 1 3/4 turns
low to medium: a bit more than a 1/2 turn
medium to high: a bit less than a 1/2 turn
This is very good spacing in my opinion and the spacing is about the same when going from high to medium to low. So I can access the level I want from either direction.
Brightness: I don't have a lux meter, but I do have a photographic flash and ambient meter that can measure brightness in EV (exposure value) units. It has a resolution of 0.1 EV and since 1 EV is a doubling of brightness, 0.1 EV is about 7% increase in brightness. So I measured my (3rd gen) Arc AAA-P against the L0P with a freshly charged Sanyo 900 mAh cell (1.40 volts open circuit). I held the light right against the white dome of the light meter so this is an approximate measure of the lumens the light emits (not the hotspot brightness).
Light -------- EV ---- Brightness # --- Relative brightness
Arc AAA-P --- 13.5 ------ 11585 -------------- 1.62x
L0P low ----- 12.8 ------- 7132 -------------- 1.00x (ref)
L0P medium -- 14.2 ------ 18820 -------------- 2.64x
L0P high ---- 16.1 ------ 70240 -------------- 9.85x
With a slightly used no-name alkaline (1.45 volts open circuit):
Arc AAA-P --- 13.5 ------ 11585 -------------- 1.74x
L0P low ----- 12.7 ------- 6654 -------------- 1.00x (ref)
L0P medium -- 14.1 ------ 17560 -------------- 2.64x
L0P high ---- 15.8 ------ 57052 -------------- 8.57x
I asked Eric for a 30 mA, 90mA and 270 mA (to the LED) current steps and he delivered. With the Sanyo NiMh cell medium is only 10% low from the factor of 3 I requested and high is only 10% high from the factor of 9 I requested (relative to low). The alkaline is very similar but high is not as high due to the cell voltage loading down. Visually they look pretty evenly spaced.
I am very thrilled with this light and would recommend it to anyone who wants a small 3-level AAA-powered Luxeon light.
Greg
