proFeign
- Joined
- Nov 13, 2004
- Messages
- 91
Hey, I wasn't able to find discussion of this anywhere else, at least not easily in any thread on CPF, but all of the NiMH AAA batteries I have found have a stated voltage of 1.2 VDC, which is markedly less than the 1.5 V of the typical alkaline and lithium AAA and AA (and C and D) batteries. On such lights as the Fenix L0P and Arc-AAA-P which use voltage/current amplifiers/regulators is the deficient starting voltage (since they were probably designed to expect 1.5 V from a fresh cell, going to cause their output to suffer from the outset? I wasn't able to detect much (if any) difference with my L0P with an Energizer E2 alkaline AAA vs. and Energizer (newer model 750 mAh, other new 1000 mAh cells on their way in the mail now) NiMH AAA, but I didn't do a very comprehensive test. It seems to me if a voltage amp is designed for a particular gain, say 100% voltage boost, for simplicity's sake, then a standard AAA would give 3V out and the NiMH cells would give 2.4 V, quite a big difference when you're talking about lower than desirable voltage to an LED. Also if it's boosted 300%, say, to have a target voltage of 6V, the NiMH, on a linear amp at least, would be all the way down to 4.8 V, way less than desirable for a nominal 6V circuit.
Just curious, and if Peter G wants to respond I would really like to know how the ARC, at least, would handle this. I have read enough to get a notion that the Arc's regulator/amp is much more sophisticated than that of the L0P, but any info is well appreciated.
Thanks!
proFeign/kelly
Thanks!
proFeign/kelly
