Hi. I was doing some work on my car the other day, and my cheapo walmart 3 million candlepower halogen spotlight broke. I could probably fix it, but it was junk anyways (not even sure of the manufturer). I decided that when I replace it, I want to go with a proper "work light", ie something STATIONARY, not hand held, though a removable stand would be OK. Also, on my last light, I had TWO dedicated car-size batteries to power this thing, and sometime I'd go through them BOTH before I wanted to stop working. This thing really ate a lot of power (maybe not compared to some other lights on this forum, but still...)
Anyway, on my next light, I want either conventional HID (ie xenon), or metal halide. I guess I'd entertain the idea of fluorescent, or a home-made array of Luxeon 3W LED's with some type of cooling fan... But I think xenon would be the most conventional choice. I'd like it to project over a pretty wide angle, not a focussed beam. I want it to be a cage-light style, like the kind you see by Craftsman for "shop lights". I have seen exactly what I want in HID style from $300 to $600 (for the size I want), and I'm sure you could get them much bigger for more money. For example, JW Speaker Corp's model 9710 would be pretty good, but it's expensive.
That's just too much for me to spent right now, so I wanted to see if anyone had any cheaper ideas for stationary 12V high efficiency work lights (I could use 120V and an inverter, but I don't want any unneccessary power loss). I was thinking of retrofitting some HID's into a craftsman "host" to use its reflector and protective cage. Has anyone done this? Which type of "host" did you use, what type of ballast & bulb? Thanks
sean
sean
