firefly99
- Joined
- May 22, 2005
- Messages
- 748
hi, How do you tell the model of Surefire tailcaps ? Cannot find any label or marking to indicate the model. Thanks
blake711 said:Size 15s a couple questions. First are the clicky caps about the same length as the standard g2n twist cap? Also I just got a G2 and it dosen't have the black rim sticking out the front. Is that a modification? Last will all those tail caps in that photo fit a g2? Thanks
RemingtonBPD said:Will the Z48 still work with the Rogers method of shooting?
Size15's said:I doubt it (I am not a shooter though).
You can remove the rubber shroud. However, I have not found a way of replacing the shroud so I would strongly urge you to consider sticking with the standard LOTC or trying the Z58.
Al
firefly99 said:Does "Lock out tailcap" imply that it is a twistie ?
What is the model number for the old G2 tailcap and new LOTC ?
Would it be possible to identify the model # of tailcap that came standard with each Surefire ? :bow: :bow:
firefly99 said:hi, How do you tell the model of Surefire tailcaps ? Cannot find any label or marking to indicate the model. Thanks
CMCadenhead said:Aren't the U2 and Z59 tailcaps the same?
Monty
