eebowler
A diode died on me yesterday in a flashlight which had 3 mins runtime on it. I removed the SMD, transistor shaped diode (only two pins connected) and replaced it with a plain ole diode. The flashlight worked but the output was significantly reduced to my estimate of 50% or less.
The diode was connected to posative out, to the LED and I believe to the coil. Connecting the two points directly resulted in a very dim light (<2mA). Is there any particular diode I can use to get the brightness back to original? (SMD components are not available here.)
Thanks alot guys.
Thanks alot guys.
