I'm sort of late here, but for the benefit of future readers of this thread I will say that the
Fischer and Paykel top loading washers deserve a look. They spin out at about as high an RPM as the majority of front loaders, but you don't need to buy special detergents. They have a stainless steel drum. And they have direct-drive DC motor/transmission systems and a user replaceable pump. These features more or less eliminate the most common causes of failures of washers. Either the pump dies or the drum gets lots of chips in the enamel and starts rusting, or the transmission dies/locks up/ or starts leaking oil.
Changing the pump on one of these is super easy. You can do it yourself without any tools. You just lift a ratchet/pall lever to allow it to untwist a quarter turn, disconnect a quick disconnect for the electrical power and control wires, then just snap the new pump in and reconnect the quick-connect. And the pump is like $30 delivered to you home.
And it was rated very very highly by consumer reports for both cleaning ability and water and electrical savings--and spin drying. We have found that it takes HALF as long to dry our clothes with this washer. We got it just about a year ago now and I couldn't be happier with it.
We got ours at Lowes (like Home Depot) for about $600 or so delivered. The controls for it are really nice, too. Everything about it is really nice, actually. The lid is a composite/plastic type material that doesn't get scratched and is nice and light. And the lid comes off completely. So you can unscrew a big plastic wing-nut at the bottom of the agitator and then remove IT completely for cleaning or what-not. And one feature I really like is that you can fill it up with clothes, then pour the detergent down the center of the agitator, and when it starts to fill with water, it gradually mixes the detergent in and pours it over the top of the clothes as they are rotated. It's really amazingly sophistacated for a (relatively) inexpensive washing machine.
I reasoned thusly: at the really low price points ($300 or so), delivery is NOT included, and that usually runs $50. Plus, if delivery is not included, it means they won't haul away your old broken washer either, so there's that cost. Then if you figure the savings over just one year from less energy usage of the washer, and less energy useage due to much shorter drying times due to high speed spin cycle, it turns out that the $600 GWL11 isn't any more expensive than the cheapest Kenmore or GE or whatever. And then for the years that follow, you actually save money.
But, on the other hand, it's cheaper than the good quality front loaders and doesn't need special (and expensive) detergent.
Plus, like I said before, it seems to me that you can keep one of these running for a very long time with very little money in repairs. Time will tell, I suppose.
Do a web search and check out Consumer Reports and all that and you'll see some of what I'm talking about.
