To be honest, the only people that sell metal reflectors are
Fivemega - as you said, only HS available atm
Modamag/Sandwich Shoppe - only camless stuff
Litho123 - once again, only camless stuff
lightedge - also camless
So i think you're out of luck until one of the above dealers/sellers create a new batch of cammed stuff. You can post a WTB on CPF for a cammed MOP...
Is cammed absolutely necessary though ? I had a bulb blow in one of my cammed reflectors due to super small opening, and manufacturing/fit not accurate enough (when i used the cam action, it made the bulb rub against the reflector opening and then
There's a trick to modding the
M@gswitch so you can still focus with camless but it takes a fair few more turns (more accuracy though). Or you can use focus shims, set once and forget.
GL
