Expired camera film?
Sigman
* The Arctic Moderator *
"The 49th State"
Digging around one of my "treasure chests", I found 8 unused rolls of expired Kodak 200 Gold 35mm film. Once I started dabbling with digital cameras - my old Minolta became very lonely!
Expiration/develop before dates are March/April 2003. Now I could just mess around with it (haven't used my 35mm in a long time!)...or should I still "count on it" as being good?
paulr
If it's been chilled (fridge) it will be fine. If it's been at room temperature, the colors will have shifted a bit but since it's print film, that would be corrected in processing. If it's been in very hot temperatures, the colors are likely pretty messed up but still correctable.
I'd go ahead and use it for casual shooting but maybe not for important stuff.
bfg9000
Kodak film actually has been very heat stable for years now. The problem is cosmic radiation exposes light spots in it over time, so feel free to use expired film for extra "arty" pictures!
RA40
So. Cal
While some films if kept in a mild storage may be okay, at 3 years with varying temps, it's probably color shifted. But ya never know so as long as it isn't critical, run it through the camera.
I have film that has been in the fridge going on 5 years over expiration. I know it is still within general tolerance for color reproduction but I won't use it for critical shoots.
sflate
Beachwood, Ohio
Camera film? What's that? My Grandfather used to tell me about that stuff!
Seriously, I just used 2 disposable Kodak cameras that were about 3 years past expiration and they worked fine. And those things usually come with the highest ISO film (800 or 1000) so I'd bet that your 200 ISO would be fine. Like others said, I wouldn't use it for once-in-a-lifetime photos though.
ABTOMAT
MA, USA
Unless it was kept in a glove compartment I'd think it would be fine. More about temperature than time. I shot some B&W film from the '60s a while back and it worked fine.
The exception to this is Polaroid film. I wouldn't count on it one day over the date.
Sigman
"The 49th State"
It's been in a cool/dry closet. I guess I'll run a roll through the camera & see how it turns out.
It's just so much more "affordable" to use the digital though! Of course there's a ton of things that my ole' 35mm can do as compared to my digitals.
Thanks for the replies!
