LEDagent
more stuff i took pictures of at 2 in the morning...
The maglight accessory kit will fit the Surfire E2 and Lambda Illuminator/Legend 2AA Bezel...
Take the clear lens from the kit and cover it with Scotch tape and trace around the lens with a razor... (I was in a hurry and i didn't smooth out the air bubbles)
Now just simply place the beamshaper on the bezel of the E2 or Lambda Illuminator.
The lenses can be switched with the red or amber lens that the kit came with. It's a little tough to put the beamshaper on the Lambda because of rubber that surrounds the bezel. But with a little pushing it will fit snugly. It will loosen up A TAD after a week or so. Just to let you know, the clip for the E2 gets in the way for a less than perfect fit, but it stays on snug... that's what counts. Hey...it was only about 4 dollars.
