Angryfox
Results 1 to 9 of 9
Thread: UWOJ The best configuration..
    Flashaholic* dpled's Avatar
    Oct 2004
    O hi O
    Default UWOJ The best configuration..
    I am looking for sum advice on how to run a UWOJ.
    Whats the best converter board... mA ect. And just how good is the U bin?
    Thanks
    Flashaholic* FirstDsent's Avatar
    Jan 2006
    Columbia, South Carolina
    Default Re: UWOJ The best configuration..
    UWOJ is my favorite emitter.
    A UxxJ bin Luxeon III at the top of its range for flux and the bottom of its range for Vf is arguably the best readily available LED emitter for flashlights. A good X-bin Luxeon V may put out more light, but cannot be made to throw like the U-bin. Plus, an X-bin Lux V is pretty hard to come by. Even the K2 has not been shown to compete with a good U-bin.
    That's why I'll still pay a premium price for the UWOJ emitters.
    By the way, WO is my favorite color.
    Bernie
    If it's worth driving, it's worth overdriving!
    Flashaholic* LumenHound's Avatar
    Apr 2005
    Toronto
    The best converter board will be dependant on what battery configuration you'll be using and what kind of run time you expect to get from your batteries. If you intend to run that UWOJ at higher currents then proper heatsinking becomes very, very important as well.
    Flashaholic* Niteowl's Avatar
    Aug 2004
    S/E Wisconsin
    Quote Originally Posted by LumenHound
    How about a 2C Mag using alk. or NiMH. NG 500 or 750 best? Still need to remove anodizing from inside tube? Or would 3x123 w/DB take better advantage of U-bin. I've got a couple blue 2C's to pop leds in.
    Mama always told me not to look into the eye's of the sun.
    But mama...., that's where the fun is.......
    *Flashaholic* IsaacHayes's Avatar
    Jan 2003
    Missouri
    NG750 *might* run in regulation, but it's on the edge I'd say. In a large light you have room for heat management so might as well try to make it as bright as possible.
    I'm going to run my u-bin at 917ma via a Wiz2 w/3xNiMH. I wanted 1000ma, but there is no wiz2 that high.
    Flashaholic* Long John's Avatar
    Mar 2006
    Spain, near Cadiz
    Hello dpled
    What's about a Fatman or N-flex?
    Best regards
    ____
    Tom
    Flashaholic kennyj's Avatar
    Jun 2005
    Orlando, FL
    Where do you get that particular bin LED from, anyway?
    Sep 2001
    Brussels, Belgium
    Smile Re: UWOJ The best configuration..
    Photonfanatic sells UWOJ, Tnc sells UXOJ.
    Romisen RC-F4 Q5, RC-G2 Q5, Solarforce L2 11074 drop-in, Surefire M2 SKU 11074 drop-in, E2e, Milkyspit KL1 SSCP4 USWOH 700mA McR18, 8AX, Fenix L1P SSC P4 USWOH Millermods 500mA driver, L2P, Millermods Mag 2D Tri-Lux UWOJ 9w
    Oct 2004
    O hi O
    Thanks everyone for the tips, now I must try to configure this into a Vital Gear FB2...anyone have any pics of there modified FB2 and what they did to it.
    Thanks
