flash....
I like the idea of LED flashlights that have no batteries, so I built this little unit out of an old 5-1/4 floppy drive head servo motor. Most any older units have these... Most all of them generate enough juice to run 4 Nichas with out trouble. (Note: the harder it is to turn the motor when removed means the magnets are stronger hence, the brighter the LEDs!)
The voltage coming out of the motor is AC so a diode makes things more efficient (although you don't need it.)
I call it the "Bud-(flash)light"
I hooked the output coils to a full wave rectifier (4 diodes) and converted to full DC. From there, connected in parallel two Memory .047F 5.5v capacitors (to store my hard earned labor.) and then to the white Nicha.
I also attached another led directly to a different pair of coils for an instant light while charging.
Top it off with a glob of hot glue and your ready to shine.
Twist the rotor for about 20 sec and you will be rewarded with a Bright slowly diminishing light.
It gives decent light for about 1 min 30 sec and stays visible for 10-15 minutes more.
Another pic...
The servo motor on the right is a really old one and is powerful, it drives 4 Nichas direct and requires your constant attention. (note my blurry fingers on the right)
And its also extremely addictive.
Another pic...
