A friend of mine just got one of these in trade, it's VERY bright! What's the story on this light? I've never heard of it, is it the father of the M4? How many lumens etc. What's it worth as he's not really into lights so I might have a shot at it!
CHC said:That one has been discontinued for some time, but may be found occassionally. I forgot the Lumen output but it sure does have the SRTH which is still available from Lagger-Pro.Com
Enjoy!
I happened to live at the address they were sent to for several years...trouble said:Size 15. you're the man! That's a very impressive lineup of SF's, how did you come by the prototypes if you don't mind me asking?
I am under the impression the N62 Lamp Assembly is still in the production cycle for SureFire. They likely don't make a batch very often though.trouble said:Does SF still make lamp assemblies for this light?
The MN60 and the MN61 work fine in the 12PM/12ZM. However, the old TurboHeads (SRTH, TRTH & "T") are not designed for such wide filaments and may not produce perfect beams in all combinations of lamp & reflector.trouble said:Is the 500 lumen lamp the only one or will M4 lamps work?
