russtang said:What tool do I use to get the "ring" out that holds the switch in a c mag?
Is there an easy way?
and a whole lot of patience...Mirage_Man said:A flat head screw driver. :thumbsup:
MM
missionaryman said:and a whole lot of patience...
You don't need to take the split ring out to remove the switch. The switch comes out the bottom.will said:the new style - a screwdriver to pry it loose from the slot.
ksbman said:You don't need to take the split ring out to remove the switch. The switch comes out the bottom.
will said:absolutely true - I thought he wanted to get the ring out - The question was how to remove the ring, not the switch.
Also - to remove the switch - new or old style - you need an allen wrench that goes through the pushbutton to loosen the contact point. That is what makes the negative path for the bulb.
