Hi guys,
I just took some photos and I have found that in comparison of the 1 watt Luxeons in a SureFire Exe reflector, the side emitters do seem to perform better. In the comparison shots below, the camera was set to capture the reflected beam so the lower level direct beam is not really even seen. Further, the high dome LED's definitely put significantly more light out in the direct, wide angle beam.
Above are white emitters; first the HD and second the SE (both driven at 500 mA)
Above are cyan emitters; first the HD and then a SE. The HD is driven at 500 mA; SE at 400 mA
Obviously the intensities are a function of luminous output and are therefore suspect. The relative size and brightness gradients are a function of the reflector and conclusions drawn from these aspects do have merit. All shots were taken with the same manual exposure settings and the images are not cropped so size comparisons are legitimate.
MORE BEAM SHOTS
- Don
MORE BEAM SHOTS
- Don
